Rough Idle???
Rough Idle???
I've recently changed the spark plugs and wires on a 88 maxima and now it's running rough? Like it want to cut off even when i'm driving and stopping at a light. Could there be another problem i've over looked?
Originally posted by TabbsMax
I used Bosch wires and ac delco spark plugs.
The Bosch wires aren't bad. But the Delco plugs might not be working. AC's are generally for GM's. Try maybe Fram's, or maybe some NGK's. The heat range and gap of Delco's aren't meant for imports.
Also, check the gap of the plugs. Just because they may be "pre-gapped" doesn't mean squat. A lot of gaps change over time, especially with shipping to suppliers, and long shelf lives.
NGK's installed yesterday for me. V- power kind. You can get them from Advanced Auto Parts stores, if you have one where you live. Theres the regular or the v-power. I got the v- power kind
Id take it they are. Thats what the pple at the auto parts stores told me.
Well, I've tried the new spark plugs and I'm still missing, I've gapped the plugs to the right specs. but, I'm still missing. Is there something else?
Originally posted by Cutlr7
Check your distributor cap and rotor, also check your plug wires. Those are alot of the times the culprit, also make sure your timing is set correctly, good luck
You gapped them to .44 right?? Dude invest in a haynes manual book. Ill let you know all of whats going wrng can be checked
Yes, I've gapped them right. And I also have the haynes repair book too. But, I'm check the cap and the distributor.
Originally posted by rhayashi
Check the connections to the injectors, they may need to be cleaned or replaced. there is a wire loom kit for about $35 to replace all six injector connectors. Also the hoses on the idle air regulator and other vaccume lines may have cracked when changing the plugs.
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
