im hooking up a monitor, which wire should i connect to the power?
I'm gonna connect the power and ground wires from my monitor to the same ones that the cd player uses. Only problem is there is 12V battery wire (yellow) and a 12V ignition/switched wire (red). Should i hook the power wire from the monitor to both or just one of those i just mentioned? Problem is I dont want to accidentally leave the monitor on.. help quick..
update: when it is off, it flicks on real fast when i am turning the car off. It stays on longer if it was on ON - shorter when it was just ACC. any idea? dont think it will cause i problem.. but i dont know
Originally posted by 96MAXIMAGXE
where did you install your tv? lets see a pic
The Frye
Sep 2, 2021 11:03 AM
