My max did something really weird last nite ... has this ever happened to you?
I was driving around after picking up my car with my body kit finally installed and my Volks back on. Then the car started losing power and the growl from my y-pipe, SI & HKS exhaust disappeared and instead I had a very wet gurgling noise coming from the car.
Then the Service Engine Soon light came on & I freaked out & called the body shop. But after driving for another 15 seconds .. everything went back to normal.
Happen to anyone else?
What the heck would have caused that gurgling noise and loss of power & Service Engine Soon light to come on like that?
Re: My max did something really weird last nite ... has this ever happened to you?
Re: Re: My max did something really weird last nite ... has this ever happened to you?
Originally posted by Max_Gator
Intake come loose?
Intake come loose?
Now that is strange. I'd check the intake, MAS sensor and make sure all the electrical connections are secure. Also might want to pull the codes from the ECU, it may have stored what happened.
Re: Re: Re: My max did something really weird last nite ... has this ever happened to you?
Originally posted by njmaxseltd
That would be my guess as well. But he says it went back to normal
Tkx!
Re: Re: Re: Re: My max did something really weird last nite ... has this ever happened to you?
How do I pull the codes from the ECU?
Tkx!
Tkx!
How to get the code:
http://vbxmaxima.8m.com/ecu.html
What the code means:
http://vbxmaxima.8m.com/ecudecoder.html
There! Use it, love it, live it!
Originally posted by 2K2DEMAX
Definitely sounds like bad gas. Happened to me once.
That's what the guy that installed my kit said it sounded like ... how bad is that for my ride?
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
