Jumppy acceleration
Re: Jumppy acceleration
Originally posted by 96SE5Spd
When I am accelerating at half throttle or less my car jumps or lurches between 3-4k rpm, will bad O2's cause this?
I have the same problem with my max. My mechanic says it could be my knock sensor or some other sensor. Sorry ,I cant remember which but he says he's gonna price how much it will cost to fix. Does anyone know how much this might cost?
Knock sensor ECU code 0304
110 dollars from the thepartsbin.com, or 165 from Nissan.
O2 sensor, about 75 dollars each, because there are two cylinder banks, therfore two paths fot the ECU to read off of, so hence 2 O2 sensors.
Knock Sensor is under the IM.
O2 sensors are on the y-pipe.
It also may be your MAF, do the MAF test, turn the car on, tap the MAF and if the car stutters, then that's your problem, again $249 from thepartsbin and about 500 from nissan.
Maybe use fuel injector cleaner.
Change your fuel filter, or maybe change the spark plugs or bettr yet, clean your TB.
I don't think the ambiebt temp sensor has to be in the flow path, mine isn't
Mines actually dangling somewhere in the engine bay, but I would suggest zip tie it somewhere close to your filter.
As for teh MAF njmaxsetld suggested that to me one time, so yea, just tap it on it's head a few times w/ your hand.
Need help
23
Oct 2, 2015 08:56 AM
