Camber Bolts Installation
Old May 25, 2002 | 10:38 AM
blackandwhite's Avatar
To them I'm like an idol
I bought the Camber kit that Eibach makes for my car w/ the Pro-kit springs. Anybody know how the installation of these works. They came with a little sticker, but it was very vague.
Old May 25, 2002 | 01:12 PM
EdgeProductions's Avatar
Re: Camber Bolts Installation
All the camber bolts are are replacement Strut tower center bolts! Remove stock on insert new Eibach Camber Bolt! SImple enough, course I have been working on headlight conversions, body work, clutch and flywheel & custom turbo fabrication work (No BS!) so this was kinda easy compared to everything else!
Old May 25, 2002 | 04:35 PM
pearl93max's Avatar
Let me know when you get it done B&W....my wheels butterfly like carzy!!! But I guess getting it aligned after I dropped it would have helped too...
-Blake
Old May 26, 2002 | 12:09 AM
mykizism's Avatar
remove the upper strut bolt and install the new camber bolt. set the camber bolt to highest positive camber setting. (cam lobe sticking outward (towards you)) to correct the camber.
it will still be negative, camber bolts dont and will not bring it to factory specs but they will do the job
it also depends on the spring you used and how low the car is
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
The Wizard
24
Oct 1, 2015 08:47 PM
dcam0326
Sep 18, 2015 04:52 PM
ag90fox
Sep 9, 2015 12:22 PM
