Dash question - what am i missing here?
Quick question if anyone can help.
On my 4th gen, one of my dash peices does not sit in right flush with the rest of the console. It's the peice that houses the clock and the rear defroster button. There's a gap right at the bottom of that peice and the top of the climate control. If I press the peice in, it will fit fine, but then it starts to pop back out. If I turn the heat on, forget it, the whole bottom of the clock peice pops out. It's like I can never get it to sit flush. Am I missing something here? Is it held in by a clip or something that maybe I lost.
It's driving me NUTS if anyone can help.
Re: Dash question - what am i missing here?
Re: Re: Dash question - what am i missing here?
Originally posted by MIXXMAX
This is a common problem when the panel piece is removed. I had the same problem when I installed my head unit. What I did to solve this was that I bought some 1/8" black weather gasket to fill in the gap. This way it looked flushed with everything else without any noticeable gaps.
I need to get around to doing mine also..
there are 2 little tabs that are on the bottom of each side of the clock unit. what you need to do is pull out the clock unit and when putting the piece back in, make shure that the 2 tabs are lined up correctly so that they will snap into the holes that are in there. also theres the clip thats on top of the clock.
Originally posted by FJC
Nismo, my tabs don't snap in. They only act as a "line-up" for the bezel. The clips on the sides hold it in. Are the 97-99 years different
