Strut Question...
Old Dec 1, 2000 | 12:06 PM
davis449
Like Sarah, I'm having that clunking noise coming from up front on my '93 SE. The weird thing is about three weeks ago I had the struts replaced. Any Ideas?
Old Dec 1, 2000 | 12:34 PM
Killermove's Avatar
hmmm....
I odn't know what it is, but I'm intrigued. About 2 weeks ago I slid into a curb and had to replace the front right control arm, strut mount, and end link fastner. The strut is also bent -- but Kaleb and I are putting Tokikos on both my fronts tonight -- so for now, I'm riding on a *slightly* bent strut.
BUT, I also noticed a "clunk" now over msall bumps/ripples in thepavement. This was not there before I got all this fixed. It will be interesting to see what KAleb and I find tonight. I breifly checked underneath and everything loks fine (wheel is on tight, FSTB is secure, endlink fastner is tight, nothing blatently wrong with strut, etc).
Hmmmm...
Ryan
ryan@fobart.net
Old Dec 1, 2000 | 01:00 PM
Sarah99GXE's Avatar
Maxima Princess
My mechanic told me that my struts weren't too bad (but I am going to replace them before they are completely shot) but he said the clunking noise was from the pad in my strut housing being shot.
Old Dec 1, 2000 | 01:03 PM
Killermove's Avatar
I'd believe that...well see what happens once I change mine...n/m
Old Dec 1, 2000 | 05:13 PM
brubenstein's Avatar
The pad that goes between the top strut mount and the body is very thin. I think that if it were bad it would only cause a squeak, not a clunk, if the strut mount nuts are tight. If everything is tightened down, I would suspect the bearing in the top strut mount. Remember that the strut rotates (on this bearing, which supports the weight of the car) when you steer. If I had any noise from the front end, I would replace these bearings when replacing struts, and/or, springs.
Old Dec 1, 2000 | 05:32 PM
thebull's Avatar
ok, if you just replaced them there is a good chance this could be the problem. it happened to me with the rear. the upper strut mounts have to be aligned a specific way. you need to have a manual to see what im talking about. this is not the case for many cars, so thats why it may go undetected. on mine the noise was a loud clunking noise that sounded as though the springs were popping in and out of the spring seat. i think this is actually what was happening. you my want to take a look at this even though it is a pain in the *** to do.
Old Dec 1, 2000 | 05:41 PM
thebull's Avatar
actually im not positive it is the same for the front. i gotta look in my manual that is at home.
Old Dec 2, 2000 | 03:14 PM
Killermove's Avatar
Well...Kaleb and I replaced my front struts last night...
with Tokiko Blues...I didn't hear any clunking afterwards last night. I'll keep an ear out -- I wasn't listening too closely last night.
Hopefully, this took care of it.
Ryan
ryan@fobart.net
Old Dec 4, 2000 | 06:53 PM
davis449
All of your replies have helped me a lot, I'm inclined to believe that the pad or the bearing is at fault here. Oh well, i am taking it to the shop tomorrow and we will see what the problem is. I will post the mechanics' replies. Thanks for the support!
Old Dec 4, 2000 | 07:52 PM
Sarah99GXE's Avatar
Maxima Princess
well I just ordered my upper insulators, bump stops & lower spring seats from Courtesy. I will be ordering the Struts & Strut mounts from Tirerack.com. As soon as I get all this stuff replaced I will let you guys know how it works out as well.
Old Dec 5, 2000 | 01:26 PM
davis449
I just got my car back from the shop, they have a part on order, they said it was the right front strut mount that was making the thudding noise. I will have it replaced by Thurs. probably. Then we will see if that fixes the problem.
Pnjboyzz
Nov 16, 2015 12:27 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
