MAF and TPS voltage specs - How to Check?
Old May 27, 2002 | 01:03 AM
vmok's Avatar
Here's a question. I'm having driveability problems with my 1990 Maxima SE Automatic.
I was wondering whether someone knew the proper way to test the MAF and TPS. I also have a 1993 SE-R and the techniques and parameters there don't even seem close.
The TPS is weird. It will go from 11.94v at idle to 0v near mid opening, then start going back up as I approach WOT.
The MAF readings I get at idle are approximately 1.1 to 1.2 volts. Is that correct with a VG30E automatic?
Thanks.
Old Jun 11, 2002 | 08:58 PM
BoyGenius84's Avatar
To check a TPS, you have to look at the waveform on an oscilloscope, so I doubt you will be able to check that. If you are getting those strange voltage readings on the TPS, you are on the wrong wires.
As far as the MAF, those readings sound about right.
Old Jun 12, 2002 | 06:31 AM
«§»Craig B«§»'s Avatar
Re: MAF and TPS voltage specs - How to Check?
Thanks.
those MAF reading are way off, you need to buy a new one; I just happen to have one for sale
just kidding, I'm not sure about the readings, those may be fine
but if you do determine that you need one, let me know; I have a used, but working, one for sale
craigbrace@hotmail.com if you're interested
-ReLLiK-
Apr 29, 2016 06:25 PM
The Wizard
24
Oct 1, 2015 08:47 PM
ballerchris510
Sep 10, 2015 09:35 PM
dcardello
Sep 3, 2015 11:44 PM
