car will die every now and then
only when i come to complete stops and its not all the time my max will die. one of my valve cover gaskets was leaking so i replaced both and the little "O" rings in the valve covers also as far as i know the leak cleared up but my car still dies any ideas, i thought that it would be a sensor but my check engine light only gives me my engine coolant temp sensor. could that be it. oh yeah im going to replace the sensor anyway
thanks
thanks
Re: car will die every now and then
thanks
thanks
Does it die only when it is cold? If so then there is a good chance it is the coolant sensor.
thanks
thanks
Originally posted by SuDZ
When was your fuel filter last changed?
SuDZ
SuDZ
http://forums.maxima.org/showthread....hreadid=116457
I had similar symptoms as you described, including high speed RPM jumping.
I saved last post, I'll save you too. It really is the Temp coolant sensor. Mine was the same way, but my check engine light never went off. The fact that yours did, its a grauntee. Don't question it, it all makes sense when you think about what the sensor does. Replace it, and you will be all set.
Hall
I had the same problem, it was the engine coolent temp.
There is a thread somewhere on this site explaining what the ects does but i can't remember where it is... do a search.
Mine sputter, when i tried reving the engine it blue out smoke and then stalled. Clean the throttle body, then change the ects ($36 from dealer). If I can find the thread i will post it here.
Hall
Hall
thanks everyone for the info
Originally posted by cmac95gxe
I have the same problem with my max stalling and jumping. I'm gonna replace the coolant sensor as well as the knock sensor. I'll post once its been done.
FLO_BOY
[QUOTE]Originally posted by cmac95gxe
[B]
NO
I'm starting to think its either my TPS or my fuel pump...In any case,
I will let you know -- but, I think the important lesson here is don't change
things unless you know its broken, unless you want to do it as part of 'maintenance'.
I'll let you know what happens -- I want to test my TPS, but I just
haven't had the time.
best,
FLO_BOY
[B]
Originally posted by FLO_BOY
FYI -- I've had that problem too -- I've changed both those sensors, to no avail!!!
Really?
Did you find out what the problem is?
Really?
best,
FLO_BOY
TPS Problem
Symtoms:
Rough idle in park and drive. Car rpm will sporatically drop to below 500rpm. Rarely feel anything going 50+mph.
Solution:
After doing a search and reading the post on rough idle, the Throttle Position Sensor (TPS ) seemed to be the closest to my problem so I deceided to investigate it. I followed the Haynes manual and determined I need to replace my TPS. The resistance values did not match the manual. However, since I did not have time to purchase one, I deceided to adjust the TPS to match what the Haynes manual says. After adjusting it to the best that I could, my car idled a whole lot better for the first couple days and now it came back but still not as bad as before. I'll hunt around for a replacement TPS and buy it then. I hope this helps someone else as this forum helped me out.
~magic_max
'96SE
Solution:
~magic_max
'96SE
my car dies every now and then as well...recently i just changed the coolant temp sensor...thought it fixed the problem...this was yesterday...then today i made a turn at about 10-15 mph...then it just dies...good thing there wasn't any car around...so does anyone knows what's the problem...i don't wanna bring the car to the dealer to charge ya all that labor and maybe for just something you can fix on your own...i got a autoshop to check on the alternator...they said it was fine...someone help
could be a number of things...just go through the list.
FLO_BOY
well i finally got it fixed... my cel would stay on and give me all kinds of messages... i ended up replacing my engine coolant temp sensor but the code was still there even though i reset the ecu. so i dicided to take it to the dealership and just so happens that my efi wiring harness had a couple burnt wires... anyway got it fixed and no more prob. plus the cel went away and everything works perfect now. hope that helps
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Maxboy23
Aug 11, 2015 11:59 AM
