V8 Swap
gearbox etc,
With an auto, a 700R4, most likely, a manual, a t-5 would be my choice. You'd have to have a prop shaft fab'd. There is a r-drive bellhousing I have seen for the Chevy small 6, have to investigate further. Someone put a multi-port 2.8 in an early '70s midget and swapped out the original clutch slave. Looked pretty clean. A 3.4 will give you up to 220hp and less weight than the L-series. I just don't like the timing belt change procedure on that motor, but once it's in-line the way a motor should be, I suppose it would be alot easier. On the 3.8 side, I have a bellhousing for that I might be convinced to part with.
There are many V8 conversions available for the L-series Datsun Zs. Since the 82 maxima is basicly a 4 door Z, I would start my conversion search with one of the Z V8 conversions. Mostly likely a Chevy 350.
Re: Rear wheel drive conversion
If it were necessary to swap from fwd to rwd then you would be correct sir.
Originally posted by rhayashi
Are you guys insane??
to go from front wheel drive to rear wheel drive is not a option...
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
