tranny dying
Old Dec 2, 2000 | 05:14 PM
max1ma97se's Avatar
ok my slushbox is feeling lik its slowly dying wtf? sometimes my tranmisisson shifts it waits like a whole sec then shifts big *** delay it wont downshift when i want it too! sob im mad im getting killed by hondas latley cause my car cant perform ne body havin same prob?? did i kill my tranny, by driving to hard? most times im useally nice to the car unless some fix up kar pulls up to me, then u know wht happpens..
Old Dec 2, 2000 | 06:44 PM
Daniel B. Martin's Avatar
There are several tests you can make with the fluid on the transmission dipstick.
1) Level. It should be up to the full mark. If not, add as required.
2) Color. It should be be bright red and translucent. If it is brown or black that is a bad sign.
3) Odor. It should have a clean oily smell. If it smells burned that is a bad sign.
4) Feel. Wipe the dipstick with your fingers and then rub your fingers together. It should be smooth and slippery. If you feel any grit that is a bad sign.
Sometimes the service life of a transmission can be extended by changing the fluid. Automatic transmission fluid is loaded with detergents, so new fluid can clean the insides of the transmission. If you decide to do this, find a shop that uses the Magic Sucker Pump which removes -all- of the old fluid. An ordinary drain-and-refill changes only about half of the fluid.
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
maxima297
Sep 30, 2015 03:32 PM
pktaske
Sep 4, 2015 08:40 AM
