my first problem with my 2k se
Old Jun 1, 2002 | 05:58 PM
lcf's Avatar
lcf
it was really hot today. 90s!! i was driving around in the city. a lot of stop and go's. all of a sudden, i start hearing a very strange noise whenever i made a turn. the sound which resembles a whistling sound. it is most audible whenever i take right hand turns. what could this problem be? any of you guys heard of this before?
Old Jun 1, 2002 | 06:08 PM
Hobert's Avatar
I've only had my car for a couple months but aint never heard a sound like that.
Old Jun 1, 2002 | 06:10 PM
yongjun's Avatar
Re: my first problem with my 2k se
my 2k used to do this.
Go to the dealer and let them check it out.
It's a simple fix
Old Jun 1, 2002 | 06:13 PM
lcf's Avatar
lcf
Re: Re: my first problem with my 2k se
It's a simple fix
ive had my car for 2 years and its never made this kind of sound. its as if its coming from the brakes but its not the brakes. somehow the steering wheel is associated with the sound because whenever i turn it to the right... even a little it makes the sound. funny thing is, the car isnt making the sound now. did it have something to do with the crazy heat?
Old Jun 1, 2002 | 06:27 PM
asu174's Avatar
Clay Aiken has fancy genitals
Re: Re: Re: my first problem with my 2k se
Dude, I had to repaint my front grill in 110 degree hell today. 90 degrees is not hot....... I wish it were 90.
Is it when you crank the wheel all the way? Or the entire time?
Old Jun 1, 2002 | 06:28 PM
y2kse's Avatar
The key, as always, is to be able to demonstrate the problem in front of a Service Writer. They generally won't fix what they can't see or hear.
Old Jun 1, 2002 | 06:34 PM
lcf's Avatar
lcf
Re: Re: Re: Re: my first problem with my 2k se
110º is hot! you win.
and well, the answer to your question is both. sometimes even turning the steering wheel slightly would make a whistle, and sometimes not. sometimes turning the wheel all the way would make it whistle, sometimes not. the sound IS coming from the outside though... and it was quite audible. like, if someone were standing on the curb and id pass by they would hear it and look at my car like wtf?
y2kse: i hope this is only a freak occurence and will not happen again. if it does... meesa think ima screeeeeeewed.
Old Jun 1, 2002 | 06:35 PM
lcf's Avatar
lcf
It's a simple fix
could you elaborate more on what the problem was?
Old Jun 17, 2002 | 06:44 AM
lcf's Avatar
lcf
my car started making the same noise again yesterday.
after it sat a while and let it cool down... it stopped?
does anyone have a clue what this could be?!
Old Jun 17, 2002 | 07:13 AM
NYC2SD's Avatar
Check the power steering fluid. Have you ever hear a power steering pump low or dry? It's makes a really disturbing noise.
Old Jun 17, 2002 | 08:40 AM
lcf's Avatar
lcf
how full is it supposed to be? there are two levels: hot and cold, and for hot its right between the max and min line. for cold though, the level is above the max line.
Old Jun 17, 2002 | 05:57 PM
lcf's Avatar
lcf
hello?
any more input?
Old Jun 20, 2002 | 04:55 PM
spaaz14's Avatar
Give your belts a little squirt of belt dressing too.....that helps lotsa noises
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
