Where is the fuel pump fuse???
I am changing my fuel filter and it says to disconnect the fuel pump fuse to release the fuel pressure but i cant find it at all. Is there another way to do this or is there anyone who knows where I could find this elusive fuse?
Re: Where is the fuel pump fuse???
once you get into the fuses, the fuel pump fuse is in the right column of fuses, in the middle. I think it's either a 7.5 amp or 15 amp fuse. there's a diagram on the inside of the fuse cover. you'll need some needle nose pliers or a fuse puller of some sort because it's not easy to pull out w/just your fingers.
