motorized antenna- how do I disconnect the motor?
I have a pioneer HU and everytime I turn it on, no matter if its CD or Radio, the antenna would come up which is normal for the pioneer. I want to disconnect the motor so it will stay down/ Which plug or wire do I disconnect?
Re: motorized antenna- how do I disconnect the motor?
i think its the solid blue....the blu/white stripe i think is amp turn on maybe you have em mixed up or u only have an amp wire
i think you can disconnect the power from the antenna side. look in near the car jack and disconnect the harness. this way you won't have to cut any wires and if you want to connect later it will always be easy to connect it back up.
so is there a way I can do it so that the antenna would still function, only it wouldn't pop up?
it'd still work just the motor would be disconnected i believe
u wana sell the motor?
Originally posted by carnal_c30
if you unplug the antenna motor harness (what max808 said) it would function... probably not very well though
Originally posted by 95emeraldgxe
my car radio sounds better without the antenna - its wierd, but true
we got 2 antenna's one is the motor one and oner is in the rear window - the stock radio uses both and switches back and forth to waterver has the better signal
I have the same quesiton. I have a kenwood recvier and the atenna goes up when its powered. I look in the back, and all i see is that metal box by the car jack. I see two plugs. I see one small one and one big harness. Both of them are connected to a metal box which says keyless entry something. So could i just take out that big harness and my keyless system work? I took out the small plug and the attena still went up. Wat should i do?
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
