300ZX MAF swap to 95Max
Do any of you know if the MAF in the 300ZX TT will work in a 95Max???
Are they the same size?? Reason being, is to apply this on my turbo application, if possible??.. Feedback would be helpful.
I don't think anyone has tried this so your on your own. However you can get wiring diagrams here http://www.z32.org/html/afmdiagnostics.shtml.
Thanks for the info! I'll give it to my mechanic.
No. I just want to install the 300ZX tt MAF unit only.
Hoping it will work well with this application.
Originally posted by Jeff92se
You mean BOTH of them?? Because just one is way smaller than the maxima unit I believe
Don't the twinturbo Z32s use two mafs and two throttle bodies? If you want to use both of them, I guess I can see it. If you are only going to use one, I don't see the advantage.
I'm not sure on this one??? If what you said is right then that is another possiblity. But I was under the impression that everything feed into one unit???
Could be one maf into two throttle bodies. Dunno
I'm suprised that this application was never done!!
Guys yhat I know that have Turbo Spec M's are using
540's and M5 MAFs in there setups. I was hoping that the 300Z
would provide the same possibilities???
Kev is running well over 300hp on his SC'd maxima. Nigel and Turbo 95 are also using stock mafs and running high 300 and mid 400hp respectively. Are you planning on running that much or more hp? The maxima already has a pretty big maf and TB.
Also, since you have a 4-gen, how do you plan to recalibrate the ecu to run the larger maf? JWT?
I would like to get somewhere above 300+ Hp to the ground using the
"Mustang Dyno" and yes it would be JWT. But I would ultimatly use "Haltech".
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
