is there a difference between a MAF bolt-on adapter and a POP-charger?
Old Jun 13, 2002 | 08:27 AM
FLO_BOY's Avatar
just curious...I mean, both items are essentially the same, so, why should I spend 4 times as much for the item?
THOUGHTS?
THANKS!!!
FLO_BOY
Old Jun 13, 2002 | 08:44 AM
dwapenyi's Avatar
Venturi or velocity stack
Old Jun 13, 2002 | 09:40 AM
FLO_BOY's Avatar
OK, some clarification:
velocity stack a la Stillen
OR
simple bolt-on MAF adapter
Does the velocity stack justify a price difference of $115 vs. $35?
Thanks!
FLO_BOY
Old Jun 13, 2002 | 09:59 AM
dwapenyi's Avatar
Stillen and JWT have them. The others do not. Is it necessary?? I think so, given that a POP style filter is **right there** on top of the MAF. The venturis/velocity stack will help smoothen the air flow and make it easier for the MAF to get a more accurate airflow reading. It may help low end torque more than high end power.
EDIT:It may help low end torque more than high end power, especially in conditons of part throttle where there's very low airflow velocity.
DW
OR
Thanks!
FLO_BOY
Old Jun 13, 2002 | 10:05 AM
FLO_BOY's Avatar
DW
Do you think the price difference justifies the added "features"?
Thanks!
FLO_BOY
Old Jun 13, 2002 | 10:16 AM
dwapenyi's Avatar
Well, just about. If you were to make your own venturi, it would cost about $50 I beleive. I definitely would go with the venturi. Maybe if you had a monsterflow filter the venturi would not be necessary b/c it straightens the flow due to the foam filter and those flow veins.
DW
Thanks!
FLO_BOY
Old Jun 13, 2002 | 10:19 AM
FLO_BOY's Avatar
venturi
um...what is a venturi? is that the bolt-on adapter?
thanks,FLO_BOY
Old Jun 13, 2002 | 10:35 AM
dwapenyi's Avatar
Look here, it's the silver dish with a hole in the middle;
http://www.jimwolftechnology.com/poprest.htm
Perhaps we should continue this thru PMs, if needed.
DW
thanks,FLO_BOY
TallTom
57
Oct 14, 2025 05:16 PM
doctorpullit
Dec 12, 2015 09:39 AM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
