should i get rims/tires or drilled/slotted rotors and breaks FIRST?
Old Jun 11, 2002 | 04:33 PM
itsgt's Avatar
I'm definately getting some 18" rims/wheels late july/early aug. But was wondering if i should delay that a bit and get the drilled/slotted rotors + performance breaks??
what have others done in the past??
Old Jun 11, 2002 | 04:44 PM
mzmtg's Avatar
Minister of Silly Walks
It's spelled:
B-R-A-K-E-S
Old Jun 11, 2002 | 04:57 PM
pocketrocket's Avatar
Originally posted by mzmtg
It's spelled:
B-R-A-K-E-S
mzmtg, you seem to be posting the same post evry other day.
You got a hot key on your computer to do this?
Old Jun 11, 2002 | 07:54 PM
itsgt's Avatar
It's spelled:
B-R-A-K-E-S
Thanks, that really helps me.
Old Jun 11, 2002 | 09:56 PM
DiscoGsus's Avatar
You should definitely get the wheels first. Because if you get any kind of big-brake kit, chances are it won't fit in your stock wheels anyway
Old Jun 11, 2002 | 11:43 PM
xHypex's Avatar
Decide whether you want to use stock wheels anymore (I have SE wheels so I still use them), and how much braking power you want. I opted to get slotted rotors/pads/lines so that I could use my 16s and 18s. I got my brake upgrade for $500 and now I can save money on tires as well I may do a big brake upgrade in the future, but at least I'm part of the way there.
-hype
Old Jun 12, 2002 | 09:32 AM
itsgt's Avatar
from what i know, fitting doesn't have anything to do with what size wheels you get i think. If i get slotted/drilled rotors & break pads... the wheels never touch any of those, so why should the size of the wheel matter?
Old Jun 12, 2002 | 09:53 AM
95emeraldgxe's Avatar
the size of the wheel matters if you want to get one of the big break kits - if you just wanna change the rotors - you will be fine...... BTW - if you need new brakes - get those first - but if not........i'd go for the rims........slotted rotors eat up your pads fast.
Old Jun 12, 2002 | 12:17 PM
xHypex's Avatar
And you know this from what experience?
I believe the saying goes something like this: Believe none of what you hear and half of what you read; and when 95emeraldgxe starts talking just stop listening (or something like that)
-hype
Old Jun 13, 2002 | 07:25 AM
itsgt's Avatar
-hype
ok, so back to my topic...I'm not gettin big break systems... just regular drilled/slotted rotors . What to get first drilled/slotted rotors with peformance break pads OR rims/tires + oem pads ?!?
Old Jun 13, 2002 | 07:46 AM
-hype
big brake kits........ common sense that the size of the rim will matter slotted rotors........think about it dum@$$ - it might not wear out your brake pad in like a day or something, but they definitely do eat them up faster
Old Jun 13, 2002 | 07:49 AM
btw- a big brake kit is different from just getting crossdrilled/slotted rotors with after market pads hypex
Old Jun 13, 2002 | 09:21 AM
xHypex's Avatar
Get the rims first and if you notice a decrease in brake performance you can always redo your brakes with whatever you feel necessary. My slotted rotors/pads helped my braking, and it also fit my budget so that's why I have what I have. The big brake kit does cost considerably more, and it also doesn't clear my 16s. Slotted rotors don't wear down pads that much faster unless you are using them for a lot of track use. The nice thing about them is they always keep the pads from glazing
95emeraldgxe I know a big brake kit isn't the same, but that's not what you said either.
Originally posted by 95emeraldgxe BTW - if you need new brakes - get those first - but if not........i'd go for the rims........slotted rotors eat up your pads fast.
And the difference is I have slotted rotors so I know what they do
-hype
Old Jun 13, 2002 | 10:43 AM
itsgt's Avatar
-hype
hmmm, ok i'll get rims/tires first.....& then i'll get slotted/drilled rotors+pads ---- im gonna get slotted/drilled rotors in any case cause mine have 68k stock, and they're really worn out.
thanks.
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
