Car is Shaking!
Old Jun 13, 2002 | 09:07 AM
Cashj2002's Avatar
Car is Shaking!
About 2 months ago I was in an accident and ever since the accident my car has been shaking at speeds between 60-80 mphs. Before the accident I got my breaks but on and they said I had abour 3000 or so miles left on my rotors before they go bad. There are so many things that it could be. I need some advice on what the problem could be.
Old Jun 13, 2002 | 09:20 AM
pocketrocket's Avatar
Re: Car is Shaking!
Cashj2002
You need to be more descriptive in the type of accident so we might be able to give better suggestions.
I'm going to assume you had a front-end/side accident. Was there any contact with your wheels (with the curb, car, etc). What type of repair was done?
Could your wheels be out of balance? Have you checked your alignment? A possibility is that your drive shaft or linked components might have bent slightly such that it appears straight but speed has a way of brining out the faults.
Old Jun 13, 2002 | 09:24 AM
Cashj2002's Avatar
Re: Re: Car is Shaking!
Well the accident didn't get past the front bumper, it didn't get near my rims just the hood was messed up. The bumper had little nicks not bad. People are telling me if could be bad rotors I need to see if the right weights on are on rims, that one of my tires are going bad. etc
Old Jun 13, 2002 | 09:39 AM
Re: Re: Re: Car is Shaking!
Bad rotors will only cause vibration when you're braking.
Weights on the wheels (I'm assuming that's wheel balancing) and that could be a culprit.
Inspect your tires, make sure there's no worn spots (emergency braking and dragging tires) or splits, thread damage, etc.
Old Jun 13, 2002 | 10:53 AM
Cashj2002's Avatar
Re: Re: Re: Re: Car is Shaking!
What about just a simple alignment?
Old Jun 13, 2002 | 06:02 PM
Re: Re: Re: Re: Re: Car is Shaking!
I think an alignment would be a good thing to do. If you're feeling rich, get your wheels balanced too.
Old Jun 13, 2002 | 07:47 PM
Jamsan's Avatar
same thing happened to me....i was actually gonna post today, but i got carried away with some other things, and well i come home, and you post my exact symptoms ....well about a year ago, i got into an accident, and my front right axle snapped and the tire got pushed back into the firewall....ever since then, non stop shaking from 60-80....also the car veeres slighlty to the right on the highway....i took back 2 times to the mechanic, and still the same ****.....they said it was the alignment, but the ****ign dumbasses havent fixed it yet.....get your alignment checked first, becasue i think thats what it could be
Old Jun 14, 2002 | 05:27 AM
Cashj2002's Avatar
But, my car doesn't vary off to the right or left. It stays straight when I let the steering wheel go. I am thinking it might be a bad tire.
Old Jun 14, 2002 | 02:59 PM
Jamsan's Avatar
well first it was very noticable ( the veering ). but then they adjsted it and it stopped veering, but still shakes between 60-80....i dunno
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
jhontelj
Aug 17, 2015 04:07 AM
Balkins
Aug 12, 2015 06:39 AM
