Idle Air Valve Cleaning
FYI
I have a 96SE with approximately 69K miles that was experiencing uneven accereration during light loads. I replaced my fuel filter with no improvment when I first experience uneven acceleration.
The idle speed begain sticking at 1500rpm when returning from higher engine speeds. So...I removed and disassembled the air intake valve and used carb cleaner to clean 'gunk' from valve assembly.
The coils for the valve motor can be separated from the magnet and valve. I cleaned components and re-assembled.
Accerlation is now smooth and idle speeds are stable.
Hope this helps others with similar problems.
Re: Idle Air Valve Cleaning
Originally posted by 96SE_dsm
FYIThe idle speed begain sticking at 1500rpm when returning from higher engine speeds. So...I removed and disassembled the air intake valve and used carb cleaner to clean 'gunk' from valve assembly.
my $0.02
FLO_BOY
Re: Re: Re: Idle Air Valve Cleaning
For sure man, you should do a write up and put it in the FAQ, just as mentioned above so you get your credit. I've read tons of posts which I'm sure this would solve their problem. You would help out the forum ! Good stuff man!
What is the difference?
Based on the research I did on this site, everyone told me to not to use carb cleaner, and to instead use throttle body cleaner...something
about the chemicals...
FLO_BOY
Re: Re: Re: Re: Idle Air Valve Cleaning
FLO_BOY
FLO_BOY
Be careful not to expose O-ring in assembly to the cleaner.
Also, check the Haynes Manual page 6-18 for reference.
ballerchris510
Sep 10, 2015 09:35 PM
03VQMAX
Sep 5, 2015 03:47 PM
sdotcarter
Sep 2, 2015 09:53 PM
