Alarm LED wiring help - where can I tap into?
I have a varad alarm scanner led and right now I have it on a switch to turn it on (I still have factory alarm) but I would like to know if there was a place where I can tap the wires into so that the light will turn on once I press lock on the key remote. thanks. I was thinking about tapping it to the stock security led but is there a better way?
ok, after a little searching I read that if I connect the LED to the + battery and connect the negative side to the ground prong of the stock LED light, it would blink along with the Stock LED. Am I correct? or is there something im missing?
Ok, I just got done doing just that- wiring the ground to the ground side of the factory led and now it blinks along with it when I arm the stock alarm. thanks.................
I am doing this also, do you remember which wire was the ground for the stock LED, the green/yellow, or the yellow/green?
Originally posted by NikeGal
Hey do you have any pics....
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
