Tire Pressure Vs. Trap Speed
hey... i was wondering if anyone could tell me how tire pressure affects trap speed. when i run, i usually put my tires to about 23-25psi. but is that hurting my top end? its hard to get good traction with anything higher than this. and i've only run an 1/8th... so my 60ft is what really matters. but will having my pressure that low make my 1/4 time worse? i might have a slightly worse 60ft, but will having less resistance on the tires get me a better time...top end? thanks.
Re: Tire Pressure Vs. Trap Speed
Once the car is moving past 40mph, I doubt the contact patch on a fwd and rwd car is that much different. In the lower gears is where the car is doing most of the shifting of weight.
As for trap speed, I 've run anywhere from 24-32psi and I've never noticed any measureable difference in 1/8th and 1/4. I'm always aroudn 75-76mph in the 1/8th and 95-96mph in the 1/4. Who says the 4th gen VQ doesn't breath up top?
Dave
Dave
I've never noticed any difference in trap speeds related to front tire pressure either. Tonight I made two runs at 32psi and two runs at 22 psi the average speeds (of both runs at both pressures) were almost identical.
