What's this
Old Jun 20, 2002 | 11:31 PM
NYC2SD's Avatar
What's this
Anyone know what is this connector for. Its on the passengers side lower air dam.
Old Jun 21, 2002 | 05:28 AM
mdeal's Avatar
That is the ambient air temperature sensor for the AC (auto AC). That guy determines how warm it is outside and feeds that info to the AC brain, as do several others sensors in the car in an attempt to adjust the AC level. Also, the air temperature sensor for the auto-dim mirror is mounted in the same location, which that sensor could be for the mirror if you do not have the auto AC unit. I have two sensors in that same location, for example, since I have auto AC and an auto-dim mirror with the temperature display.
I just replaced my ambient air temperature sensor, as you have pictured, due to some weird activity of the AC.
Old Jun 21, 2002 | 05:38 AM
Padsy's Avatar
Boost.....
I disagree, I believe it is the light sensor for lightspeed
Old Jun 21, 2002 | 06:41 AM
Shaydz's Avatar
I disagree as well, I think it is an electronic whistle to warn deer that you're coming in at mach 1 (come to think of it... the whistle sound would be behind you then, wouldn't it?)...uuhh.. Nevermind.
Old Jun 21, 2002 | 06:53 AM
Padsy's Avatar
Boost.....
If Im going the speed of light, and I turn on my HID's what will happen.....???
Will I see my self in the auto-dimming rearview mirror??
Old Jun 21, 2002 | 08:58 AM
MichaelAE's Avatar
Two points for creativity.
Old Jun 21, 2002 | 08:59 AM
NYC2SD's Avatar
Will you even need an auto dimming mirror? You'll be outracing the glare!
Old Jun 22, 2002 | 02:16 AM
mingo's Avatar
the auto climate control sensor is right by your gauge cluster. that little hole thing.. that wire connector is something else.
Old Jun 22, 2002 | 02:23 AM
Tony Fernandes's Avatar
Re: What's this
Why don't you unplug it and see what doesn't happen?
Tony
Old Jun 22, 2002 | 03:06 AM
KaxMaxSEAE's Avatar
You can't go the speed of light. But you can get close, and your HIDs will come on.
Yes.
If you can handle the math, go take a modern/quantum physics course that discusses relativity.
Really weird **** happens...
