Harlan RPM switch and ME VI
Originally posted by Jeff92se
You searched though all the install threads correct?
Ryan
Yeah his site...
Hopefully he will get his site up and running again. But, there are a few options to consider.
-John
I bought it directly through Harlan
You guys bought the rpm switch direct? How about a distributor?
-John
Not that I'm aware of.
Originally posted by Anachronism
Did anyone have any luck in finding a VI activation wire that was already on the Max? (97+ only I guess)
-John
Re: I bought it directly through Harlan
Originally posted by Mr Cranman
I bought the RPM switch directly through Harlan which was only like $50 (I think he makes them on the side) , which is about half the price of all the other RPM switches out there. I think if you search some more you might be ale to get the MSD RPM switch cheaper than a $100 but probalby not to much cheaper...or find another RPM switch but I hadn't taken to much time on that. But, I think I'll have to be looking into finding another RPM switch out there for the same price for everyone that is interested in the VI.
-John
-John
MSD Ignition
RPM Activated Switches
These RPM Activated Switches will perform a variety of different functions from turning on a bulb or solenoid to activating an MSD Timing Computer at a desired RPM. The RPM Activated Switch, PN 8950, has two activation wires; one to ground a circuit and the other to open a circuit. Simply plug in an RPM module and wire the Switch to the circuit you want to activate. When the engine RPM reaches that amount, the circuit is activated and will remain on until the RPM falls below that amount. The RPM Window Switch, PN 8956, has two RPM adjustments; one to activate a circuit, while the other deactivates the same circuit. This Switch will supply then remove ground to a circuit. This is a great feature to deactivate nitrous before the engine's rev limit is reached. Both Switches can be used with stock inductive ignitions or an MSD Ignition and can handle up to 1.5 Amps. No RPM modules are supplied so they must be ordered.
Will this replace the Harlan RPM switch? Called MSD tech support and they were not very well informed in regards to this application. I believe the members here are more well informed and based on what I see it can be used to activate a solenoid which is part of what is needed for this set up.
Any help is appreciated with this!
DL
Re: Re: I bought it directly through Harlan
Originally posted by dlicari
Will this switch work?
MSD Ignition
DL
MSD Ignition
DL
-John
Re: Re: Re: I bought it directly through Harlan
Yep that will work perfectly. But if you can wait for dafro to post you would save yourself about $50 bucks...But then might have to wait 2 weeks to get the RPM switch from Harlan.
-John
-John
I sent an email to Dafro.
DL
-John
-John
Here is there new site
Re: Here is there new site
Originally posted by dafro
here is there new site for everyone that needs it.
http://www.harlan-engineering.com
-John
Re: Re: Here is there new site
Thanks so much for the new info. I think I speak for everyone when I say, "I really appriciate it!!!"
-John
-John
Ryan
Potentially stupid question
I was wondering what this switch does. I'm hoping this is what brings the high end power. If so, I would be interested in the VI. If I could somehow make the switch set at 4,200 that'd be great. Considering that I only pull the RPM's past 4,000 when I want to take-off. So I guess my question is, can you set different points on the RPM for the VI to kick in? Has anyone determined what is optimal?
thanks
thanks
RPM switch ordered
Thanks Dafro and Cranman.
Just ordered the RPM switch. Looks like Harlan is trying to make it easier to use than MSD.
Need to get a few more things and I will be installing the ME VI and then the JUICE!!!!
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH
DL
DL
Re: Potentially stupid question
5,000 rpm was found to be the optimal switch over point for the mevi. Ian dyno'd his w/ different rpms and actually lost a little power when it was set too low. You can set the rpm switch to activate whenever you want. But lower is not always better.
thanks
thanks
thanks
thanks
Re: Re: Potentially stupid question
Originally posted by Mishmosh
I take it you have an AUTO. No matter... I'm not sure why you'd want to partial throttle your way past 5k rpm. The point is the power is there when you need it, ie. WOT. If your not really jumping on it, there is no point to stay in gear...
Nope, all 5-speed here. It's just that I normally shift at 3,200 in 1st and below 3,000 in all other gears under normal street driving. On the freeway, I pull the car higher depending on acceleration needed. So usually, if I go beyond 4,000 RPM I'm either flooring it, and/or in need of more power. Maybe somewhere between 4,000 and 5,000 RPM would be good for me.
Re: Re: Re: Potentially stupid question
Yeah, I don't go redline that often...only when I'm racing. I usually pull a redline at least once per tank. I've had this car since 97 and never had any incidents until 6 months ago. I've hit the rev limiter 3 times this past year. Like everyone else, I have an intake, y-pipe, cat, b-pipe, and 5th gen muffler for a complete exhaust system upgrade. But I have a ton of weight saving parts too: UDP, 13" Brembo 2 piece cross-drilled lightweight rotors, and lightweight forged 17X8" SSR Integrals. All this and I'm planning on popping in a lightened forged flywheel and ACT clutch when I swap out my 5-speed for one with an LSD. I'm thinking about having my tranny swapped along with the intake manifold. I should have a really fast naturally aspirated Maxima. As of now, I'm pretty darn fast, but nothing to brag about.
thanks
thanks
http://www.howstuffworks.com/question517.htm
HerpDerp1919
Sep 29, 2015 02:02 PM
