ASAP Help WHAT FUSE TOO CHANGE
Re: ASAP Help WHAT FUSE TOO CHANGE
Originally posted by kevlo911
i blew the fuse that controls teh door lights, map light, and the dome light.....which fuse do i change?
Re: Re: ASAP Help WHAT FUSE TOO CHANGE
Originally posted by asu174
I don't know, but you have two fuse boxes to choose from. One is under the hood. One is under the dash by the hood popper. They are both labeled.
ya i no but wat fuse the labels don't help much
OMG PLEASE HELP ME the car remote doesn't work either, ir the trunk light, my freind is soo scared so help him out, i looked at all the fuse but none seem to be blow so wat else could be the problem??
will the car crank??
does the radio turn on??
do you still have headlights??
you have to give more info to get help sweety
btw..take two deep breaths...cause your typing sucks
Originally posted by ms.thicknes
what were you doing when you lost all of the lights??
i was trying to get a power source from the map light, i wired it all and test it and it worked but when i started put everything together and tested it again it did not work. everything thing else works, the car turns on, radio/ac works.
Also when the car is on the door open light and trunk open light are lit very lightly on the dash
here is what doesn't work - - Map light, Dome light, Both door lights, Trunk light, Remote does not lock/unlock
plzz help my friend ASAP
BTW ms, y an FSU tag on a max
GO GATORS
Ooh, I have an idea. Look at the diagram in your manual. And if that doesn't work, yank each fuse, look at it, determine if it is blown. If it is blown, replace it. If not, put it back.
This might seem like a long process, but it will be a hell of a lot faster than waiting for car enthusiasts to give you a straight answer on which FREAKING FUSE to change.
why james....i'm so impressed....your answer is much better than mine!!!
I had the same thing happen to me when I "touched" something while changing the dome light. I believe I used a test light and found one of the fuses in the interior fues block (not the underhood fuses) to be blown. I don't remember which one, but I know my key fob quit working. I think it was the dome light fuse itself but at the time I was puzzled how the whole issue got started and was ****ed, so I don't remember what fuse it was.
[QUOTE]
I had the same thing happen to me when I "touched" something while changing the dome light. I believe I used a test light and found one of the fuses in the interior fues block (not the underhood fuses) to be blown. I don't remember which one, but I know my key fob quit working. I think it was the dome light fuse itself but at the time I was puzzled how the whole issue got started and was ****ed, so I don't remember what fuse it was. [QUOTE]
ya the key fob doesn't work on my friends either we will try doing that test light thing tomaro
yes we will check the fuses tomaro but most likly we will go to the dealer cuz he has to get some maintanence done so dealer will hopefullly fix it undert warrenty
Originally posted by JBWhitley
It is possible that it is a fuse that is not directly related to the light. Most of the time when something happens to a part of the car, the manufacturer will make something obvious happen. You will need to check every fuse to make sure it is not a blown fuse.
Keyless, interior lights, security not working
thank you guys, thank you Maxima.org. I just got back from a sterio installation place, they relocated/reinstalled my amp, when I get home, Keyless doesn't work, interior light doesn't work, security doesn't work. I called them back and they were like "we can't get it back in here until Monday" I was pissed, they screwed up my Max's security system doing an amp install? This is not right. I searched the thread and found that the dome light fuse will cause all of these issues, I checked it and it was blown-I guess the dude didn't take off the batter leads before doing the install, thanks a** h***. I replaced the fuse and it's working fine now-thanks to Maxima.org I won't have to go medieval on their asses.
Originally Posted by David W.
this thread helped me out!
Just print out the post next time or save the link...
Now can anyone find a post with kevlo asking which cai is better?
AaronL
Nov 15, 2020 11:52 AM
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
