What type of oil?
Old Jun 27, 2002 | 10:08 PM
SkiLlz's Avatar
What type of oil?
my 95 Maxima has approximately 130,000 miles on it.
what type of oil should i put in it? any suggestions?
10w30 was the one that firestone had put in, is that the best one?
i never used synthetic oil. Should i start using it?
Old Jun 27, 2002 | 10:12 PM
JustTry's Avatar
Re: What type of oil?
Personally, i dont use it, but all I am hearing is good resluts about synthetics....
Old Jun 28, 2002 | 04:39 AM
02SM520's Avatar
Try Mobil 1 Synthetic oil...
I tried on 1991 Honda Accord Ex sedan with 164,000
and it gave more smooth power...
Time to have oil change.....
For my Samsung SM520 I am going to get Mobil 1 Synthetic oil.
Old Jun 28, 2002 | 10:18 AM
iwannabmw's Avatar
5W-30 or 10W-30 is fine. Since you're in CA, 10W-30 is fine year round. 5W-30 will give you slightly better startup protection and fuel mileage. If your engine is starting to get a little tired, 10W-30 would probably be your better choice.
Old Jun 28, 2002 | 10:59 AM
95emeraldgxe's Avatar
I used to use Amsoil in my car, it was pretty good. But i think Mobil 1 is better
Old Jun 28, 2002 | 01:48 PM
iwannabmw's Avatar
Why?
Old Jun 28, 2002 | 02:01 PM
maxedout95's Avatar
I use Castrol
Old Jun 28, 2002 | 02:21 PM
CSever05's Avatar
Mobil 1. Best oil in the world.
Old Jun 28, 2002 | 02:53 PM
karguy's Avatar
Converted 1997 SE with 120,000 miles to AMSOIL 0W-30 Synthetic oil. Used AMSOIL Engine Oil Flush before installing the Syntheyic Oil. Have about 135,000 on it now without any problem what so ever. Had used Castrol GTX 5W-30 before that. Changed filter and oil every 3,000 before Synthetic conversion. It was not using oil before and is not now.
Old Jun 28, 2002 | 03:33 PM
JMAXIMA's Avatar
it really depends on your car. if your car is burning oil with regular oil 10w-30, you don't want to use synthetic, it will just burn even worse. when i had my Supra, i tried both... reg. oil wouldn't burn too bad, but synthetic would burn about a quart every 3000 miles. i suggest just try some different oil types. but in my maxima w/ 73k i use mobile syn. 5w-30... with no burning even @ the strip. if a syn. burns in your car, try a blend... and if you are still using oil with a blend, get some castrol 20w-50. that stuff is like cold maple syrup... really really thick. i used it in my Supra for a while, but i think it slowed it down a bit.
Old Jun 28, 2002 | 04:23 PM
iwannabmw's Avatar
Not necessarily. One big factor in oil consumption is the oils NOACK volatility rating. This test determines the evaporative loss of oils at high temperatures in percent weight. Significant evaporative loss of oil leads to excessive oil consumption and destructive changes in the oils properties. Not all synthetics (or regular oil's for that matter) are created equal. For example, Amsoil 10W-30 has a NOACK score of 6.6% while Mobil 1 10W-30 loses 14.98% of it's weight.
Of course, if the engine is burning oil because the rings are shot, not just high temperature operation, all this doesn't apply.
Old Jun 28, 2002 | 04:33 PM
JMAXIMA's Avatar
leaking valves or rings is what i was refering to... but you mentioned that mobil loses 14% of its weight... over what time is this calculated? i change my oil about every 2.5 months or 3000miles, and the level is almost exactly what was put into it.
Old Jun 28, 2002 | 06:54 PM
iwannabmw's Avatar
It's not a mileage interval, it's the amount of time exposed to higher temperatures. The test measures the oil's weight reduction under continuous exposure to high temperatures. This only comes into play during sustained high rpm and high power situations. You mentioned 3000 miles, but unless you are very hard on the car, you shouldn't really notice a difference. The VQ's also don't have a tendency to burn oil. In engines that have a tendency to use oil on a regular basis, such as Honda Preludes, the NOACK score is more of a factor. I have a testimonial from someone who has a turbocharged RX-7. Using Castrol Syntec his engine burned a quart every 700 miles. After switching to Amsoil 10W-40, he now only burns a quart every 1500 miles and got another 3 mpg as well.
As an example as to how it can affect a VQ though: I've run both Mobil and Amsoil on the track and in everyday use for 8K miles. The Mobil report came back with the statement that the oil a (5W-30) was reading between the ranges of a 5W and a 10W oil. I read that as the lighter parts of the oil were starting to burn off under the high oil temps. experienced on the track.
Back to your question, I don't know the time or temperature of the test, which is ASTM D5800, but I should be able to find out on Mon. if you're still interested.
Old Jul 5, 2002 | 07:48 AM
02SM520's Avatar
I try to find Mobil 1 5w-30 sync. motor oil but no luck..
(Seoul, Korea)
So yesterday I bought 3 Liter of Mobil 1 5w-50 Sync. motor oil.
Made in France. Mobil 1 the best motor oil I ever used..
Old Jul 8, 2002 | 04:31 PM
iwannabmw's Avatar
Okay, the Noack Volatility test is done at 250 degrees for one hour.
Old Jul 8, 2002 | 06:14 PM
Eric L.'s Avatar
Well seeing that your Maxima already has 130,000 miles, what you've been doing to maintain it must be the right thing. Just keep maintaining it, and it will go 200,000+ miles.
I use Mobil One 5w30, and change it every 5,000 miles along with a Nissan OEM filter.
Old Jul 8, 2002 | 07:39 PM
JsL's Avatar
JsL
Why would 5W-30 give you slightly better startup protection and fuel mileage compared to 10w-30? Do they offer the same protection? Thanx
Old Jul 8, 2002 | 08:05 PM
iwannabmw's Avatar
The 5W-30 is lighter in weight, especially during colder temperatures. This allows it to flow easier to protect your engine when you first start it. Since it is a lighter weight, as your engine warms up there will also be less resistance from the oil, resulting in better fuel economy. At operating temperature, there is almost no difference between a 5W-30 and 10W-30 of the same brand. Only in extreme heat/load situations will the 10W-30 protect better. If you live in warmer climates, startup protection is less of a factor so the 10W-30 might be the better choice. In colder climates, the properties of the 5W-30 become more important.
I run 5W-30 year round in temperatures ranging from 0-100 degrees. Oil analysis indicates there are no problems despite the abuse the car gets put through. Hope this helps clear things up a little.
Old Jul 9, 2002 | 12:33 AM
JsL's Avatar
JsL
THANX!!Wow, I've been losing out...next oil change will be 5w-30. I live in San Fran, so the temp range is 45-85. They finally started to carry Mobil 1 5w-30 at Costco, but its the new Supersyn formula and not the old tri-syn stuff
Old Jul 9, 2002 | 03:02 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
My dealer uses Valvoline 5W30 or 10W30 (depending on season) & so far I've been happy w/ it
Old Jul 9, 2002 | 03:19 PM
JsL's Avatar
JsL
Update...I just went to a different Costco today, and they only carried Super-Syn 10w-30, no 5W-30
Old Jul 10, 2002 | 10:16 AM
iwannabmw's Avatar
Since the SuperSyn is relatively new, Costco might have all the weights in all their stores yet. You can usually buy jugs of Mobil 1 at Wal-Mart or K Mart tends to have decent sales on the stuff every once in a while.
Old Jul 10, 2002 | 10:46 AM
MaxJag's Avatar
How much does a quart of Mobil 1 cost? I'm in Kuwait and there's no
local gas stations on the base.
Old Jul 10, 2002 | 01:20 PM
iwannabmw's Avatar
Anywhere from $3.50-$4.75/qt. depending on where you shop.
Old Jul 10, 2002 | 01:30 PM
97BLKMAXSE's Avatar
iv been using valvoline 10w-30 and fram oil filters should i change or is this good to use
97BLKMAXSE
Old Jul 10, 2002 | 08:34 PM
iwannabmw's Avatar
97BLKMAXSE
Well, Fram filters are junk and aren't worth the money. You can do much better for "cheap" oil filters. There have been a few links posted about oil filter studies.
Valvoline 10W-30 may be fine depending on where you are, your driving conditions and what your looking for in an oil. It's kinda hard to make a blanket statement like that as everyone has different priorities.
Old Jul 10, 2002 | 11:23 PM
97BLKMAXSE's Avatar
well im in mass and i guess i drive my max fairly hard what kinda oil and filter do you guys recomend
97BLKMAXSE
Old Jul 11, 2002 | 05:03 AM
karguy's Avatar
97BLKMAXSE
Good quality synthetic engine oil such as AMSOIL, Mobile 1 or Redline. My choice in oil filters is AMSOIL/Baldwin followed by Mobile 1 with Synthetic media and the Nissan OEM OIL Filter. The AMSOIL and Redline Synthetic transmission oils make a big difference in our transmissions whether 5/6 speed manual or Automatic. In your 97 the only plug to use is the NGK Laser Platinum OEM plug which is NGK PFRG5-11, most others fall short when compared to this plug. Welcome you to the Forum, you'll have access to hundreds of members who will share their experiences and ideas with you in the pursuit of your Maxima goals.
Be well!!!!
Old Jul 11, 2002 | 05:56 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Ok.
Do you have a full breakdown of your oil analysis results after using both oils so that I can take a look at it? Did you go the same mileage between oil changes with each oil? Did you use the same filters and just change oils? I assume you have baseline analyses of both oils with lab proof that Mobil 1 is "better", so I'm curious as to what empirical values specifically indicate that it is better.
Teach us, PLEASE!
Old Jul 11, 2002 | 05:59 AM
bill99gxe's Avatar
Ok.
Do you have a full breakdown of your oil analysis results after using Mobil 1 so that I can take a look at it? Do you have links to how the "Best oil in the world" award was giving to Mobil? I assume there was a study done that I just haven't read yet. I also assume you have baseline analyses of oils with lab proof that Mobil 1 is the "Best oil in the world", as I'm curious as to what empirical values specifically indicate that it is better than the rest.
Teach us, PLEASE!
Old Jul 11, 2002 | 06:51 AM
iwannabmw's Avatar
97BLKMAXSE - There is a big meet this Sat. in Hopkington if you're interested. More info is at http://forums.maxima.org/showthread....hreadid=126743
Old Jul 11, 2002 | 11:57 AM
bill99gxe's Avatar
*bump*
Old Jul 11, 2002 | 01:42 PM
TheNip73's Avatar
Originally posted by bill99gxe
*bump*
What does *bump* mean? Fill me in as I am seeing it all over the forums and it personally annoys me. Moderator or not I think this practice should be brought to an end unless it has some unforseen meaning I could not figure out.
Old Jul 11, 2002 | 05:03 PM
iwannabmw's Avatar
It brings the thread to the top of list so hopefully more people will read it.
Old Jul 11, 2002 | 05:21 PM
TheNip73's Avatar
Thanks. I will stick to my guns and say lame, yet again.
Old Jul 11, 2002 | 06:10 PM
240sxxx's Avatar
I use 10W-30 in the summer and 5W-30 in the winter
the oil: Tri-Synthetic from Mobil 1
Old Jul 11, 2002 | 07:49 PM
bill99gxe's Avatar
We seem to have a couple of experts chime in and say that Mobil 1 was the best oil in the world and I wanted further information and links that lead them to this conclusion.
My questions (on the previous thread page) have been unanswered, so I *bumped* it. If you read the entire thread, you would probably understand the context of the bump.
I'm still waiting for the experts to lead me to the truth about Mobil 1
Old Jul 11, 2002 | 08:38 PM
TheNip73's Avatar
I read the whole thread, but in parts. Its all good Bill. You want an answer. Now I understand. I will say I agree Mobil 1 is a great oil. In fact, i use it. I too would like to see some links. Make me feel even better about my lubrication choice.
Old Jul 11, 2002 | 09:31 PM
DigitalTexan2u's Avatar
Amsoil all the way!
Old Jul 12, 2002 | 12:55 PM
kmax's Avatar
Today I received an oil report from Blackstone Labs for my '97 Max. Since I've had the car for almost a year and love it I thought an oil analysis would be useful.
I use Mobil Tri-synth 10-30w with an OEM filter. The oil had 4500 miles on it, the filter was new and no oil was added between changes. The oil was five months old for this test.
I drive four trips at 1 1/2 miles each 5 days a week. The rest of the mileage I put on is 80% highway and 20% city.
The engine had 68,000 miles on it at the time of the test and I do not know of anything to be wrong. Basically, it runs great.
The report generally states that all wear is at or below the average for this type of engine. The TBN at 6.5 is in their words strong, meaning very good. They went on to say, "suggest running 6,000 miles next sample".
Hopefully, this will help someone decide.
