power wire fusing & other fusing questions
Old Jul 3, 2002 | 08:57 AM
itsgt's Avatar
for the power wire...there is a fuse on the wire that is near the battery side....should i put in a fuse at the other side as well(that connects to amp)?
Should i put fuses on turn on led wire as well?
What fuse sizes should i get?
thanks.
Old Jul 3, 2002 | 09:41 AM
H.N.I.C.95's Avatar
Look at your specs that came with your amp it will tell you
Old Jul 3, 2002 | 11:22 AM
itsgt's Avatar
ok, i'll look for specs on fuse size......but as far as setting up fuses should i buy some more and put them around like on the other side of the power wire(near amp), on the turn on led wire ?
thanks
Old Jul 3, 2002 | 11:37 AM
H.N.I.C.95's Avatar
No, that would just cause more problems than solutions.
Old Jul 6, 2002 | 12:03 AM
MrGone's Avatar
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
look under fuses.
this link is in the audio forum resources stickied at the top of the page.
btw, clife notes for teh site. you only need a fuse at the battery end, no more than 18" away but the sorter the better. you also need fuses at a distro block if you change the wire gauge.
double grounding is your friend, that is taking 2 wires (same gauge as your power) and grounding them to different locations.
MrGone
tsi6001
Oct 3, 2022 10:23 PM
2k0to2k3
Aug 18, 2015 09:59 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
