Hiding place for bottle?
Old Jan 9, 2003 | 05:55 PM
98_Maxima's Avatar
I am just about to install my Zex bottle in my car and was wondering where would be a good hiding place for the bottle? The reason I am going to hide it is because I am going to race at the track for money and the first thing the people I am going to race are gona say,"you got Nitrious." Any recommendation.
Old Jan 9, 2003 | 08:30 PM
MaxSpeedSE's Avatar
Re: Hiding place for bottle?
You know how thoes people into sound systems and make thoes walls to put there amps in...you could put your bottle way in the back of your trunk, and make a wall overing it...making your trunk smaller
just my 2 cents
Old Jan 9, 2003 | 09:09 PM
98_Maxima's Avatar
That sounds like a interestin idea! Do you think there is anyway were I can place it somewhere besides the trunk?
Old Jan 9, 2003 | 09:23 PM
MaxSpeedSE's Avatar
No clue
Old Jan 9, 2003 | 09:31 PM
WizzaMax's Avatar
Safety would dictate the trunk in the sedan the only bet for assurance of "what if"...
you could remove your spare (which you should do at the track anyway)
and mount the bottle down in the sump...no one has ever asked about my bottle and tech did not even look in teh trunk so who cares if they know if you are juiced or not.
Old Jan 10, 2003 | 08:29 AM
SLC I30t's Avatar
but it has to sit at a 15 deg. angle unless you remove the syphn tube but then you could mount it on the back of the seat then put up paneling or your speaker box next to it to hide it... but its pretty obvious under the hood if you have n2o.
Old Jan 10, 2003 | 09:01 AM
Jime's Avatar
If it wasn't for the labels and arrows could you spot my 100 shot wet setup?
If so you are better than one of the tech inspectors we had at a race this year. He wanted to know why I wanted to run in the boosted class (turbo/supercharged/nitrous). When I told him I had nitrous he had another close look and agreed. You really have to know what you are looking for.
Old Jan 10, 2003 | 11:53 AM
Aaron's Avatar
Langley AFB Sux
deezam..........clean install!
Old Jan 10, 2003 | 03:23 PM
SLC I30t's Avatar
from that picture no, but checking out the engine... yes I think so.
Well knowing that people aren't familiar with our engines it would make it easier to conceal it. If a honda freak looks at our engine it looks a bit confusing, so wrapping your lines in rubber would conceal a lot.
Old Jan 10, 2003 | 03:50 PM
DCmax's Avatar
Woah. Jim, where did you actually mount your solenoids?
Old Jan 10, 2003 | 04:15 PM
Jime's Avatar
If you look at the right hand bottom of that picture its labelled, solenoids, purge valve and relay. There is a cavity behind the front strut bar and all thats in there is a relay or something for the cruise control. I moved that over and attached it to the firewall and put all the nitrous stuff down in that cavity and then covered it with a piece of plastic I painted flat black. You can see the bolt holdng it down right on the head of that arrow.
It was an NHRA tech inspector that checked it and couldn't see the nitrous, so I thot I did pretty good at hiding it. The black plastic loom stuff really blends in with the stock wiring etc and I used it for the all the nitrous, fuel and electrical wiring.
Old Jan 17, 2003 | 07:12 AM
ReddoG_Max's Avatar
When my NX kit comes in what I plan on doing is making a small box out of MDF a little larger than the bottle. Put carpet around it and stick my beautiful 1980's house sub into it..Bingo...hidden nitrous, custom stereo
Old Jan 17, 2003 | 01:05 PM
mzmtg's Avatar
Minister of Silly Walks
Go to a junk yard and get old heater hose or wire loom to conceal the lines and wiring. You wont be given away by shiny new loom or hose covering your stuff.
Old Jan 17, 2003 | 10:54 PM
JAIMECBR900's Avatar
If he is going to be racing anyone for money and they don't know enough about cars to look where they should for N2O.....they deserve to lose not only the race but also ALL their money.
aw11power
Oct 10, 2021 04:57 AM
TKHanson
Nov 24, 2018 01:39 AM
Junebug1701
Sep 25, 2015 01:54 PM
220k+ A32
Sep 23, 2015 03:38 PM
