What setup to get? and a couple ?'s
Old Jan 20, 2003 | 10:51 AM
bill4max's Avatar
i have a 97 max and was interested in maybe putting nitrous in it. I am new to the nitrous scene so first off what setup should i get, nx express or nos i here good things about both also where can i get the best prices on these kits? i only want to run a fifty shot and play it safe so do i need any other upgrades to my car for this or should i be ok? also the only other thing i want with my system is a window switch but where can i get the kind that do not have to be modified for the maxima? Thanks
Old Jan 20, 2003 | 10:55 AM
Aaron's Avatar
Langley AFB Sux
Re: What setup to get? and a couple ?'s
Use the search function..........loads of nitrous info....
Old Jan 20, 2003 | 11:29 AM
Jime's Avatar
1. Did you read all the FAQ's at the top of this forum?
2. It also makes a difference if you are auto or manual trans for the window switch.
3. I am pro NX because of the no brainer setup and tuning. You can also go to a higher shot before you need to upgrade your fuel pump etc. Also you can get away with a 190lph low pressure pump which is cheaper and you don't need an aftermarket FPR.
4. Kits are available for $450 + or -.
5. Read all FAQ's, research other boards etc and then decide.
Good Luck
Jim
Old Jan 20, 2003 | 03:26 PM
bill4max's Avatar
my car is a 5speed and i have searched through many forums but just cant make up my mind.
Old Jan 20, 2003 | 04:07 PM
Aaron's Avatar
Langley AFB Sux
If you have 500 bucks..........get the NX wet kit....
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
