Nitrous Fuel Pressure Problems
Old Feb 2, 2003 | 02:25 PM
Ramius83
After installing the SARD FPR, I can't get the fuel pressure right on my current dry setup. Everytime I change the Fuel bypass jet, I still get a contant 50psi reading on my FP gauge. And I am running WAY LEAN because my EGTs are incredibly high. I have checked all my vacuum hoses and they are all zip-tied. I have a bad feeling that the vacuum line going to the SARD is somewhat too big, but it is only 1/8" vacuum line that I could barely fit over the fitting. Anyone have any idea? I am not too too worried about this because I am going direct port on my MEVI, whenever I can find all the plumbing parts required to convert my dry setup to the dp setup. Thanks all......
Old Feb 2, 2003 | 02:41 PM
mtrai760's Avatar
'Trynna' is not a word
Re: Nitrous Fuel Pressure Problems
You have upgraded your fuel pump haven't you?
Old Feb 2, 2003 | 04:21 PM
Ramius83
Re: Re: Nitrous Fuel Pressure Problems
Me Mtrai760
Good guess Mtrai, but that was one of the first things I did when I first installed the dry setup more and a year ago. I got the Walbro 255lph fuel pump.
Old Feb 2, 2003 | 04:34 PM
mtrai760's Avatar
Re: Re: Re: Nitrous Fuel Pressure Problems
Maybe a piece of debris is stuck in the regulator valve (blue anodized thing) did you pull that apart yet? What nitrous pressure are you running?
Mtrai760 Ramius83
Old Feb 2, 2003 | 04:42 PM
Ramius83
I am currently running a 100 shot, .047 nitrous and a .037 in the bypass, still no luck. Tomorrow, between work and school, I will take a look at the solenoids and all....
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
aminus21
Sep 12, 2015 04:53 PM
conansriver
Sep 11, 2015 10:26 AM
