what is the most miles on your "juced" engine?
I have had mine for well over two years. And to be honest with you, I spawned JAIMECBR900 lol. Anyways, I had about 120k on the odometer, and now I am at 166k with no problems what-so-ever. The compression of each cylinder is almost identical to the compression of the engine when I bought her with 100k on the odometer.
that's definately a good news...I thought only low milage engines could handle nitrous
Is any autoshop could check compression in the cylinders? Or does it require some very specialized equipment?
it's pretty simple and for less than what you would pay a mechanic, you have the tools to do it yourself for free many times over.
I've been running nitrous for almost 2 years with the mileage approaching 110,000. Compression in all cylinders are almost identical and have not noticed any drop since I've had the kit installed. I've ran as high as a 75 shot dry problem free. Do the compression check yourself, it's as easy as it gets. Remove your spark plugs, hook up compression tool, turn the igntion. Repeat with each cylinder.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
Apr 8, 2018 09:23 AM
raffivegas
Aug 23, 2015 09:54 PM
