Want to run nitrous on automatic...
Old Mar 31, 2003 | 02:23 PM
venompwr2's Avatar
I have a '95 maxima gxe, auto, and I am looking into nitrous kits. I am looking to run a 50-70 shot and I want to know if I NEED anything else done to the tranny or engine to accomodate the increased power. I am aware of the switches and all that for the NOS. I just want to know if there has to be any tranny mods or coolers or anything that has to be done as well. Thanks a lot,
Justin
Old Mar 31, 2003 | 02:28 PM
Jime's Avatar
Re: Want to run nitrous on automatic...
Justin
I just bought one of those. My plan is to install a B&M Trans cooler and do the drop resistor mod.
http://bgarner.tripod.com/1995nissanmaxima/id3.html
That will hold a 50-70 shot pretty easy.
Old Mar 31, 2003 | 02:56 PM
SonicDust187's Avatar
Re: Re: Want to run nitrous on automatic...
Jime: why didn't you go with a DPI setup?
Old Mar 31, 2003 | 03:06 PM
Jime's Avatar
Re: Re: Re: Want to run nitrous on automatic...
Because I like the Wet setup and don't see any real advantage to running DPI up to a 125-150 shot. It seems to work just fine as is.
I do hope to run a bit quicker this year with the 95 I bought. Not because its a 95 but I will be doing some major weight reduction and also doing some other nitrous/fuel mods as well.
Old Mar 31, 2003 | 06:01 PM
venompwr2's Avatar
but can I run the nitrous w/o a trans cooler? The nitrous will rarely be used, and the shot isnt very big. Am I ok w/ the stock trans and no cooler?
Old Mar 31, 2003 | 06:04 PM
Jime's Avatar
A trans cooler is a good idea even if you are N/A. They are also pretty cheap, ie around $50 for a good B&M.
Sure you can run without it, would I? No.
Old Apr 3, 2003 | 07:47 PM
waveridr85's Avatar
where to get a tranny cooler?
Old Apr 3, 2003 | 08:14 PM
Donkey®'s Avatar
wat
www.jegs.com
Old Apr 4, 2003 | 06:00 AM
waveridr85's Avatar
what other parts will i need to buy?
Old Apr 4, 2003 | 07:37 AM
Jime's Avatar
If you buy the B&M kit it will come with hose, clamps etc. Some people claim the hose is not long enough but mine was fine, measure and make sure before you take it apart.
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
