how to read EGT gauge??
Old Apr 20, 2003 | 10:07 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
Hey All,
I just switched my A/F guage to a EGT pyrometer. I was wondering how Im supposed to read this thing.
When exactly am I running rich and when lean? Will the temp rise significantly when i'm rich? How does that work?
On normal driving conditions,idle is at 600 degrees, normal driving conditions are 1000, punching it normally is 1300 and jucied is about 1450.
THanks for the help! =]
Also, Now that I have my own probe, I can hook the A/F gauge up to it, would it be more accurate?
Old Apr 21, 2003 | 12:05 AM
DCmax's Avatar
If you're at 1300 at WOT off the bottle and 1450 WOT on the bottle you are lean.
Old Apr 21, 2003 | 05:41 AM
ejj's Avatar
ejj
I'm was way hotter NA than 1300. In the 1/4 I would hit 1500 NA.
Where is your probe mounted? That will vary your readings a lot. No, you cannot use this probe for a AF guage...this measures temperature, the AF guage needs an O2 sensor which measures oxygen content. Very different.
Old Apr 21, 2003 | 09:54 AM
WizzaMax's Avatar
I learned the hard way the A/F ratio gauge (autometer btw) is a waste of space...
you would need a wide-band 02 sensor installed to get a good reading and I tend to think (now) that the egt is more informative...I like the A/F info the SAFC gives me better.
Old Apr 21, 2003 | 09:56 AM
ejj's Avatar
ejj
What was the hard way?
Old Apr 21, 2003 | 10:18 AM
Donkey®'s Avatar
wat
He bought one and installed it????
Old Apr 21, 2003 | 11:01 AM
ejj's Avatar
ejj
Or trusted it and blew something up...??
Old Apr 21, 2003 | 11:10 AM
Donkey®'s Avatar
wat
Either or...
Old Apr 21, 2003 | 11:38 AM
ejj's Avatar
ejj
Either or...
Right, and if something blew up, I wanna hear about it.
Old Apr 21, 2003 | 07:13 PM
WizzaMax's Avatar
nothing that dramatic...I thought I had it wired up right, never saw anything dramatic, found a graphic online that said"this is what it should look like when working"
mine looked nothing like that and then I saw Hoon's and it was working right
anyway I felt it was useless...so I replaced it with a boost guage
Old Apr 21, 2003 | 07:24 PM
Eat Naaawwwzzzzz
heh, I learned the hard way as well..Mine just didnt seem to work corectly. Anyone wanna buy mine?
What should the gauge do whem Im running lean? What should happen if I run Ruch.
I just learned I had little next to none nitrous left in the bottle so I was squeezing fuel and air
Old Apr 22, 2003 | 11:27 AM
CBass69187's Avatar
EGT will rise as you run lean, they will decrease if you run rich
Old Apr 22, 2003 | 12:53 PM
[maxi-overdose]'s Avatar
2nd post here in this form
800c (1500F) is my limit. anything after that is bad for your engine. The reading is more accurate if it is taken on the manifod. I have it installed on the ypipe and I set the warning light to go off at 760 because the location and the exhaust gas will get cooled off a little.
I think weather your car is running lean or rich is based on how fast the temp increase. It will increase when you boost your car or floor the pedal. But if it increase in a really fast manner, that means it is leaning out.
I usually get 620c when cruising at 70 on a flat road. Partial throttle will increase the EGT faster than boosting....probably the amount of boost (SC) is too small for the FMU to detect.
Old Apr 24, 2003 | 04:30 PM
SonicDust187's Avatar
Will a dyno tell me if one is running rich or lean? And is it is how would I modifiy it without SAFC?
Old Apr 24, 2003 | 07:58 PM
PCGuRu2K's Avatar
You'll need to get a FPR.... On a dyno they can hook up a wideband o2 sensor and they can measure your air/fuel ratio.
Old Apr 24, 2003 | 08:06 PM
Oh ye, I am going to wait to put the system on till i get the genx2 upgrade, egt, fuel pressure, nitrous pressure gauges and a y-pipe, so that i can have them installed at once and then go dyno. I should start looking for 2 step colder plugs now.
Old Apr 24, 2003 | 08:10 PM
PCGuRu2K's Avatar
I don't think you'll need 2 step unless your pushing 150+ shot.. I'm only using 1-step colder on my setup.. I think with 2 step you're performance when n/a will suffer until you spray..
Old Apr 24, 2003 | 08:14 PM
Did you get your kit?
Old May 1, 2003 | 09:33 AM
Eat Naaawwwzzzzz
i need to dyno and see my air/fuel mapping...
andone jknow a good dyno in socal?
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
