Variable jetting for smaller shots
Old Apr 25, 2003 | 01:49 PM
WizzaMax's Avatar
I am looking for info on locating compatible jets smaller than 32 for my ZEX dry setup and larger than 38.
These are the hi and low range I have in the current jet set that I can play with to do the three "shots"
Long story short, I want to try a smaller (35 or so) shot with the SC to see how it acts and the effect on boost pressure/ acceleration/ driveability...THE BREAKDOWN IS AS FOLLOWS:
55 shot:
32 nitrous jet
36fuel jet
65 shot:
35 nitrous jet
34 fuel jet
75 shot:
38 nitrous jet
32 fuel jet
So I want to know about possible sources and jet combinations rather than just trying it out with different ones and running blind...
Old Apr 25, 2003 | 01:54 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Won't you run really rich with the big fuel jets?
If know the NX kit will run fairly rich with 18 (f) and 31 (n) jets... but with the dry kit, you're bumping FP up even higher, right?
Old Apr 25, 2003 | 03:21 PM
CalsonicSE's Avatar
Hi Kev!
For a dry kit, what ppl usually refer to as the fuel jet is actually a fuel pressure bypass jet. You tee it with your fpr vacuum line. The larger the fuel pressure bypass jet, the lower your fuel pressure will be when spraying.
Old Apr 25, 2003 | 04:37 PM
Y2KevSE's Avatar
Originally posted by CalsonicSE
Hi Kev!
I see said the blind man..... thanks!
Old Apr 25, 2003 | 05:07 PM
xHypex's Avatar
Hi Kev!
I know it's basically flow dynamics, but will you check my logic on jetting.
1) The larger the nitrous jet the larger the shot (larger jet = more nitrous flowing through, but at lower pressure)
2) The smaller the bypass jet the greater the fuel pressure (smaller jet = more pressure on the FPR which results in an increase in fuel pressure)
I'm with Wizza on the tuning. Even with a fuel pressure gauge and an EGT it must be pretty hard to get the right jet settings. Are there any equations that help you decide what you should be using? If not, are there any charts besides Mardigras or sx7r's charts for nitrous shots (jet/nitrous pressure) and recommended fuel pressure?
-hype
Old Apr 26, 2003 | 09:48 AM
WizzaMax's Avatar
exactly...but the big thing right now is that ZEX does not offer any other jet sizes...so I am looking for another company that may have jets that will fit and can allow for the variable amounts I was asking about.
Old Apr 27, 2003 | 09:22 PM
Ramius83
Are you able to post a pic of the jets?????
Old May 2, 2003 | 10:18 PM
SR20DEN's Avatar
VQ Wizard
NOS jets should fit for the Zex setup.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
bbsitum
Sep 6, 2019 07:31 PM
msellas
Sep 23, 2015 09:16 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
