Track Night Scare
Old May 2, 2003 | 12:37 AM
Iron Lung's Avatar
Track Night Scare
I have a friend that I let run my car at the track at least once everytime we're there. He's a good driver and can usually equal or better my best time for the night. Tonight he wanted to try out the nitrous, so I give him the keys. I tell him to do two things: Don't spray in 1st and shift before 6k. He launches pretty good(2.2 60), shifts into second and hits the nitrous. The tires light up and the motor bounces off the rev limiter 3 times(with nitrous spraying). Shifts into third, takes it to the limiter and it bounces once. I just knew that was it for the motor. I walk over to the car and its purring like the day I bought it. What a damn good motor. I ask him what happend and he said he wasn't expecting the nitrous to hit so hard and that inside the helmet it was quiet and didn't realize what was happening utill it was too late.
On the bright side I did get a new best, but still traction was hard to come by.
Old May 2, 2003 | 06:00 AM
SonicDust187's Avatar
How much are you spraying?
Old May 2, 2003 | 06:03 AM
PCGuRu2K's Avatar
At least he didn't missed shifts when spraying.. That would be bad
Old May 2, 2003 | 08:17 AM
mtrai760's Avatar
'Trynna' is not a word
Dude, you have a 5spd, your using nitrous, and you don't have a window switch?
Old May 2, 2003 | 08:18 AM
Why would I need a window switch with a 5 spd?
Old May 2, 2003 | 08:20 AM
ejj's Avatar
ejj
Not smart. Get a Harlen one...its only like $50, and you won't have to worry about the rev-limiter ever again!
Old May 2, 2003 | 08:35 AM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
Omg, I wouldnt even think of squeezing manually with a 5 speed! !!
If you want to keep your motor and tranny get the switch.
Itll be easier for you to race as well...
Can concentrate on other things...
Old May 2, 2003 | 08:49 AM
Jime's Avatar
At our track I have not met anyone with a window switch. I didn't even know what one was until I read it on here. Some of these cars are 10 and 11 sec cars too.
Old May 2, 2003 | 08:55 AM
Where do I buy the Harlen switch?
Old May 2, 2003 | 09:01 AM
mtrai760's Avatar
http://www.harlan-engineering.com/
Old May 2, 2003 | 09:07 AM
ejj's Avatar
ejj
Manual guys, or auto guys? I can see not having one with an auto, but I would think about it with a 5sp. If you're wheels hop and you don't get off quick enough, you're flirting with disaster.
Old May 2, 2003 | 09:09 AM
Jime's Avatar
Mostly manual guys Eric, I am one of the only auto's, somewhat of an outcast.
Old May 2, 2003 | 09:10 AM
Do I need the window or the RPM switch? I think the Window switch.
Old May 2, 2003 | 09:11 AM
ejj's Avatar
ejj
That sucks.
I always assumed window switches were a common thing...
Although, I suppose they'd only be necessary in cars with a fuel-cut rev limiter. Aren't most cars ignition-cut?
Old May 2, 2003 | 09:12 AM
ejj's Avatar
ejj
Yes, a window switch.
Old May 2, 2003 | 09:16 AM
I just ordered the window switch. Thanks for the info.
Old May 2, 2003 | 10:29 AM
What rpms should the window switchbe set for? I am thinking of 4000rpm-6400rpm.
Old May 2, 2003 | 01:22 PM
Eat Naaawwwzzzzz
3200 is good =]
Old May 2, 2003 | 02:04 PM
Iron Lung's Avatar
I'm spraying 100 shot. Don't think I'll get a window switch. I'd rather trust myself(not my friends anymore) than to trust a switch which may not work(I've got one that dosen't work, never did). I myself have hit the rev limiter while spinning when I first got the system. But now I know when to let off. Wheel hop isn't that bad with the urethane motor mounts.
Old May 2, 2003 | 07:00 PM
ejj's Avatar
ejj
You're not really trusting the switch, its more of a backup in case you mess up.
$50 is a lot less than the cost of a new motor.
Old May 2, 2003 | 07:20 PM
Jime's Avatar
That sucks.
Yes they are ignition cut thats why I can't see the necessity for a window switch. As soon as you hit the rev limiter the ignition is cut so you can't do much harm.
I have seen a few 5 speed guys doing a burn out and hitting the rev limiter and then realizing they had their nitrous on and not doing any damage so I really can't see the requirement in the real world.
Old May 2, 2003 | 07:52 PM
ejj's Avatar
ejj
Yeah, if we had an ignition cut I would bother with one either. However, bad things can happen with a fuel cut system like ours.
Honestly, is there a point to having a fuel cut system opposed to ignition? I wonder why Nissan went that route?
Old May 2, 2003 | 09:05 PM
Battle Max's Avatar
I believe it just takes concentration....WIth my zex arming switch set up all i do is switch it up and down accordingly. I never use it in first gear either i rely on my driving to get me through first gear. You have 500 rpm's of leadway time before you hit the rev limiter just need to practice some self restraint.
Jon
Old May 2, 2003 | 10:10 PM
SR20DEN's Avatar
VQ Wizard
Most EFI cars are actualy fuel cut NOT ignition cut. Ignition rev limiters are generally the aftermarket ones. If you spray any type of wet kit you can run the risk or over revving the engine because of the supplemental supply of fuel.
Miket2006
Mar 1, 2021 03:55 AM
mkaresh
Mar 12, 2018 06:48 PM
jonreidhead
Jan 6, 2016 09:38 AM
fx4five
Oct 1, 2015 04:58 AM
