New way to launch with nitrous w/o slicks
Old May 4, 2003 | 11:19 PM
Iron Lung's Avatar
I tried something out and it actually worked pretty good for getting off the line with some power and not spinning. What I do is turn my bottle opener on then off again to put pressure in the line @1100. Then I take off, get a nice little boost in first without the heavy hit of the initial nitrous spinning my tires like they were in the air. Then after I shift to second I turn the bottle back on and off I go. I still get a little wheelspin spraying in second, but it's not as bad because there is about a half of a second lag before the nitrous hits in second, because of the air in the line. It the best solution I see right now until I can get some slicks.
Old May 4, 2003 | 11:26 PM
xHypex's Avatar
You must really like to multitask while you're at the track since you seem to enjoy doing everything manually If you want some nitrous traction control wouldn't it be easier to just control the flow with your momentary switch?
-hype
Old May 4, 2003 | 11:49 PM
Iron Lung's Avatar
-hype
Yeah I've gotten pretty good at multitasking Once that nitrous hits and it delivers a constant 1100psi, there is no way to keep from spinning. This way its just enough nitrous to really cool down the air coming in so I get that nice wintertime 10 degree weather type acceleration off the line.
Old May 5, 2003 | 05:48 PM
xHypex's Avatar
So even if you just hit the momentary and let off (less than 1 second of activation) it breaks the tires loose that badly?
-hype
Old May 5, 2003 | 07:18 PM
Iron Lung's Avatar
-hype
yeah its that quick
Old May 5, 2003 | 07:47 PM
JAY25's Avatar
your words makes me want to install this kit but 50 is a tad too much for now to experiment with
Old May 5, 2003 | 08:00 PM
Iron Lung's Avatar
A 50shot with the s/c? Or on your brother's car?
Old May 5, 2003 | 08:05 PM
JAY25's Avatar
too much for my car. I believe the sentra can handle 50 shot even though it has 140K
Old May 5, 2003 | 08:07 PM
mtrai760's Avatar
'Trynna' is not a word
I always just used a monetary switch. With a 100-shot I got bad wheelspin in 1st-3rd if I hit it off the line, but if I waited till about 4.5k in 2nd, it wasn't so bad. I know a lot of people also use a push button to activate it, which would help alot since you could just release if you started spinning. Whatever works for you though...
Old May 5, 2003 | 08:12 PM
SonicDust187's Avatar
How do you 5spd guys keep your nitrous off in first gear and when you go wot in 2nd the nitrous is on?
Old May 5, 2003 | 08:25 PM
xHypex's Avatar
The only way would be to use a momentary switch and/or the method Iron listed above.
-hype
Maxima_Joe
Nov 25, 2015 08:19 AM
bumpypickle
Sep 20, 2015 08:22 AM
Xi MaX SC
1/4 and 1/8 Mile Racing
Aug 7, 2015 08:47 AM
