Automatic Nitrous?
Old May 18, 2003 | 06:18 PM
Methamphetamine's Avatar
Automatic Nitrous?
I came across this article in Super Street....it sprays when your hit WOT...is that safe?
Old May 18, 2003 | 06:23 PM
ch13f's Avatar
Im pretty sure thats how most systems get setup, those cute red buttons on the shift **** are mostly just for the movies.
Old May 18, 2003 | 06:25 PM
LOL, cute red?
Old May 18, 2003 | 06:36 PM
TylerBorg's Avatar
most systems that people use are wired with a WOT switch and then an activation switch... you activate the system, hit WOT, and spray comes out... simple enough
Old May 18, 2003 | 06:37 PM
elchino's Avatar
Those cute red buttons are the way nitrous was activated in the "olden days." But like everything else, technology evolves and more engine-friendly methods have come about. WOT switch is one of them. However, many people used to do a WOT switch by placing the activation button underneath the gas pedal so that when you floored it you would hit it. Many people still use a button on dual-stage set-ups.
So yes, WOT is safe. You really don't want to spray nitrous anytime else.
Old May 18, 2003 | 11:58 PM
CalsonicSE's Avatar
I use the WOT switch in conjunction with a push button switch. The push button switch will not work unless the WOT switch is also tripped. This is good because I'd like to make sure that my auto tranny has downshifted to it lowest possible gear before I spray. Of course, neither the WOT switch nor the push button switch will work if my system activation switch isn't on.
Old May 19, 2003 | 07:53 AM
WizzaMax's Avatar
same here...momentary switch in addition to the integrated WOT switch.
Old May 19, 2003 | 08:54 AM
xHypex's Avatar
My system will only activate if my window switch, WOT switch, arming switch, and FPSS are activated I'm going to add a momentary switch for traction purposes though. Do you guys have any pictures of your momentary switch? I can't find any that I really like.
-hype
Old May 20, 2003 | 10:20 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
I use the "old fasion" red switch =]
I like to squeeze when I want
Old May 22, 2003 | 10:14 AM
ToYLeT902's Avatar
JET Speed Lab
red means, purge, or run
Old May 22, 2003 | 01:53 PM
CalsonicSE's Avatar
-hype
I have the one made by NOS..but it's nothing special...it's just a little blue button at the end of a black cord. You can get one at summitracing.com or jegs.com
Oh yeah I forgot to mention, my arming switch is a key....i can simply remove it, just in case valet or nissan service ppl are tempted to try out the nitrous...hehe
Old May 22, 2003 | 07:23 PM
WizzaMax's Avatar
mine I loomed inside a black four foot lead that I can hold in either hand and initiate when I want...the end of each of the two leads is color coded...
red for purge with about 4 inches red loom
black for spray with about 4 inches add'l black loom
I will take a picture tomorrow...
MaxStock
Dec 5, 2016 05:19 PM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
2kmaximel
Sep 16, 2015 03:19 PM
