Purging question
Old Jun 9, 2003 | 01:44 PM
euromaxima's Avatar
Purging question
I don't know much about nitrous but what causes the purge valve to go off. is it a button or what? do you have to run the nirtous through your engine to make nitrous spray out of the purge valve?
thanks
Brandon
Old Jun 9, 2003 | 02:28 PM
CalsonicSE's Avatar
The purge valve is just another solenoid like your nitrous solenoid. Yes, it's button-activated. Instead of directing whatever nitrous/air you have in your line pass to your motor, it directs it to the outside.
Old Jun 9, 2003 | 10:40 PM
WizzaMax's Avatar
just so you know...the wiring is straight forward as it comes...one wire ground the other switch button activated power...does not matter which one as long as you protect with tape and keep clean.
Old Sep 25, 2003 | 08:35 AM
SonicDust187's Avatar
Does anyone here know what type of a clear or black hose I can use that is flexible and will withstand the cold temps of purging? I would like to route the lines in such a way that my car would purge out of the grill like a bull.
Old Sep 25, 2003 | 09:22 AM
Jime's Avatar
I have just used that small plastic clear plastic hose you can get in a plumbing store with no problems, I am sure the clear gas line would work too. There is really not much pressure because it is open to atmosphere on the other end.
Old Sep 25, 2003 | 10:03 AM
teejnut's Avatar
I use a flexible copper line, bends and stuff pretty easily.
Old Sep 25, 2003 | 11:00 AM
BJJ's Avatar
BJJ
I used the small flexible white tubing from home deot, works perfectly and it's cheap. My purge comes directly out of the hole in my nissan emblem in the front grill, its great to just hose people with it when they aren't looking. I will see if I can find a pic for you.
Old Sep 25, 2003 | 06:41 PM
elchino's Avatar
I have steel tube through the cowl. Got it coming out on my side. That way I'm sure the line is ready when I get a plume. Check out the sig
Old Sep 25, 2003 | 09:27 PM
Nismo's Avatar
Nice,I been thinking of this idea- since I dont use my wiper blades, im going to drill a hole out the sprayer nozzles and rig the purge to spray out of both of those.
Old Sep 28, 2003 | 09:28 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
toward your windsheild????!
Old Sep 29, 2003 | 12:06 AM
Nismo's Avatar
havent gone out to work on it since the purge is still comming in the mail but I was thinking of drilling out that piece that has the 2 nozzles in it and route a tubing out and have it purge straight up both of the sprayers. I dunno if it will work but Ill find out
Old Sep 29, 2003 | 04:26 PM
Synki's Avatar
Use a copper line. You can get this at a local automotive store.
Just make sure it purges away from the vehicle.
Old Sep 29, 2003 | 06:24 PM
Nismo's Avatar
anyone have any underhood pics of how they route their purge lines?
Old Sep 29, 2003 | 07:01 PM
My comes out of the wheel well.
Old Sep 29, 2003 | 07:40 PM
Nismo's Avatar
I found this
http://www.speedshop.org/store/scrip...?idCategory=24
anyone else know of similar stuff?
Unclejunebug
Apr 2, 2016 05:42 AM
tseng1023
Oct 15, 2015 08:30 AM
Socalstillen
Sep 26, 2015 12:01 PM
