quick ? for those with NOS Bottle Heater
Old Jul 3, 2003 | 01:22 PM
JDM4LIFE's Avatar
what wire is positive and which is negative? i got this with the bottle when i bought it all used and i don't have the wiring instructions. thanks...
http://www.geocities.com/horrorfreakopc/DCP_0114.JPG
neither wire has a stripe on it to signify which one it could be.. which one is which?
edit: you'll have to copy and paste the url link into a new browser due to geocities being a pain...
Old Jul 3, 2003 | 02:38 PM
Jime's Avatar
Re: quick ? for those with NOS Bottle Heater
There is no positive or negative. The heater is basically a big resistor that disipates heat when power is applied. Same principle as a solenoid. Hook either wire to ground and the other to + it makes no difference.
Old Jul 3, 2003 | 02:39 PM
JDM4LIFE's Avatar
great, thanks for the help!!
Old Jul 5, 2003 | 06:34 AM
SLC I30t's Avatar
Jime, do you use the thermostats on the blanket? I can't seem to keep mine in place, they keep falling out of the blanket
Old Jul 5, 2003 | 11:53 AM
Jime's Avatar
Mine is NX and its pressure controlled not temp, but I don't use it either, I manually control it by turning it on and off.
Old Jul 5, 2003 | 12:00 PM
JDM4LIFE's Avatar
Jime, on a dry kit, the TEE you have to hook up... mind helping me with the way it's supposed to be setup? do i understand correctly that one side of the T is connected to the solenoid part, the opposite side of the T goes to the fpr, and the t-side of the T is connected to the vacuum line that was originally going to the fpr?
Old Jul 5, 2003 | 01:41 PM
Jime's Avatar
You are taxing my memory I haven't played with a dry kit for over a year. I would have to look at the drawing again and I haven't been able to find one online.
Sorry
Jim
Old Jul 5, 2003 | 08:41 PM
xHypex's Avatar
That's correct. The line from the nitrous pressure regulator (blue anodized thing) and the line to the FPR face each other. The vacuum line goes on the perpendicular portion of the tee.
-hype
Old Jul 6, 2003 | 08:51 AM
JDM4LIFE's Avatar
-hype
thanks, that's what i'd assumed it was, but the instructions had some label for one of the lines that didn't exactly fit right. thanks!!
howardis
Dec 11, 2019 06:10 PM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
RWCreative
Sep 21, 2015 11:01 AM
