Dry Kit Fuel Pressure Rising After I Let Off The Gas
Old Sep 10, 2003 | 10:48 PM
teejnut's Avatar
Well, I just installed the NOS Dry kit last weekend and got the bottle refilled today. Went out for a test run and disconnected the 2nd solenoid to see if my fuel pressure got bumped up enough (50 shot so .32 nitrous jet and a .42 bypass jet). My FP went up to about 52 at WOT then when I got off the gas it jumped up to 62ish (which it shoudl be at with the .42 bypass jet) then jumped back down to the stock non-nitrous range.
I believe its my fuel pump thats the problem. But I just wanted to make sure its that. I remember reading something like that here on the forum but I can't find that same thread.
Any advice would be helpful! =)
But yeah I guess I'll just have to order the walbro pump and an aftermarket fpr. What do people recommend for FPR's? sxr7 (sp?) isn't selling the SARD anymore, huh?
TJ
Old Sep 11, 2003 | 11:27 AM
CalsonicSE's Avatar
The problem is your OEM FPR - it tends to do that.
Old Sep 11, 2003 | 11:31 AM
teejnut's Avatar
What would the resolution be if it was my OEM FPR? New fuel pump and aftermarket FPR?
I found the post where DCMax had the same problem, he changed his FP and FPR to fix it.
Old Sep 11, 2003 | 12:32 PM
xHypex's Avatar
I have a Walbro pump with a stock FPR and my autometer FP gauge still jumps after I stop spraying. I believe it has to do with the way the gauge operates.
Right now I'm running the Walbro pump with no bypass jet (Iron Lung is doing the same) because I can't get a large enough jet to drop the pressure to where I want to be. Without a bypass jet at all I still get 72psi, and with a .042 bypass jet I get about 95psi.
-hype
Old Sep 11, 2003 | 10:20 PM
teejnut's Avatar
I think I have to agree with CalSonic how it might be the stock FPR. Either way I think I'm just going to get a new FP since I'll need one sooner or later.
aminus21
Sep 12, 2015 04:53 PM
asianstyle
Sep 10, 2015 11:30 AM
dcam0326
Sep 7, 2015 07:26 AM
