Nitrous Oxide Kits $750 Canadian
Old Sep 24, 2003 | 02:00 PM
Sin's Avatar
Sin
I posted a while back on the results of the nitrous setup that I put together myself.
http://www.geocities.com/sinsupload/
http://www.geocities.com/sinsupload1/
http://www.geocities.com/sinsupload2/
http://www.geocities.com/sinsupload3/
http://www.geocities.com/sinsupload4/
In that run, I ran a 100 shot. I also have a vid of the maiden voyage of the 100 shot, but can't fit it on geocities. I'd be more than glad to send it to interested buyers.
My setup is for sale. Here is a copy and paste from a local Maxima board that I am a member of.
Just a vid of me racing a 19psi Talon TSI (on an industrial lot private road). I love the look on his face as the Maxima eats him up in 2nd and 3rd once my tires stopped slipping (stock Toyo A05's with not too much life left in them). I was slipping through all of first, and even second. He pumped me off the line with his 5K off the line launch with his AWD. As soon as 2nd started getting some grip, that stopped, and I came up on him pretty quickly. After 3rd, we were beginning to run out of road. 0-60 took about 5 seconds, and I let up in 3rd before the 1/4 came because of lack of runoff. Estimated 1/4 times should be 13.75-14.00 that night.
BTW, I was putting down a 100 (at the wheels) wet shot that me and my engineering buddy put together ourselves
- Magnesium Alloy Bottle that holds up to 12 lbs of N2O
- Custom length, self-crimped stainless steel braided lines with reusable hose ends (can be removed from lines and reused on newly cut raw line)
- Military spec solenoids able to withstand 20 G
Basically, a kit better than the NX wet kit, for approximately 2/3 the price. And you know what guys? It's for sale. My buddy and I are now marketing custom nitrous setups with and without installs. You can specify size of bottle, length of lines, etc. for a true custom install. We can make the setup as visibly obvious or as hidden as you would like. Want your bottle mounted in a fake subwoofer box? How ‘bout in the back seat in a gym bag seatbelted in place? We will do it all. If you are serious about running nitrous oxide, please contact me at sin_liew@hotmail.com.
I also distribute gasoline additives able to raise octane over 100 octane as well as providing in cylinder lubrication and in cylinder heat reduction.
I run a 100 shot on one step colder plugs, gapped to .033", on 98 octane fuel with extra cylinder lubrication and additives to help with high cylinder temperatures. BTW, the BKR5E-11 gapped phat for mileage absolutely LOVES the 98 octane in terms of performance and mileage, but does have a less smooth idle.
With a 75 shot, I was pounding Acura CL Type-S 6-speeds like they were Pintos. With a 100 shot, I was able to make up the deficit of FWD to the TSI's AWD with 19psi of boost.
Apr 16, 2020 05:15 AM
howardis
Dec 11, 2019 06:10 PM
Pied
Sep 26, 2015 03:29 PM
