Fuel Cells???
Old Oct 5, 2003 | 11:55 PM
David89Max's Avatar
Fuel Cells???
Ok Im just getting into nitrous and what i was wondering if you decide to go with a wet nitrous system is it good to go with a fuel cell rather than going into your own fuel supply.
Old Oct 6, 2003 | 04:01 AM
Jime's Avatar
I use a 1 gal cell with a separate pump, regulator etc. Its very easy to setup and you can use any kind of race fuel in small quantities like that vs having to put it in you tank.
Old Oct 6, 2003 | 10:12 AM
David89Max's Avatar
thanks for the info but i didnt even think about what octane to use. Now is it better to use racing gas i guess it would be better bang right?
Old Oct 6, 2003 | 11:58 AM
Jime's Avatar
I use it to keep the detonation monsters at bay as opposed to a better bang. Using a higher octane fuel gives virtually the same result as lowering you timing.
Old Oct 6, 2003 | 10:23 PM
Nismo's Avatar
do you have a pic of your aux fuel cell setup? I want to see how thigns would look. Ive seen i30crab's setup once and seems like hes running 2 cells
Old Oct 6, 2003 | 10:35 PM
Jime's Avatar
This is where I did have it, I am working on a new location for next year.
http://forums.maxima.org/showthread....ight=fuel+cell
Old Oct 7, 2003 | 01:09 AM
Nismo's Avatar
I was reading that post in the link and about the fuel TEEs, Is getting the proper tee size is to allow a better fit? or is it because the NX tee is too small to provide flow? right now I have the nx tee but I havent sprayed yet.
Old Oct 7, 2003 | 03:57 AM
Jime's Avatar
The tee with the kit is 1/4" and the Maxima fuel line is 5/16", you MUST put in the proper size or it will leak.
Old Oct 7, 2003 | 01:54 PM
Nismo's Avatar
so the only concern about using the improper size is leaking am I correct? or will a 1/4th tee be too small to supply the correct flow?
either way Im buying the correct tee today but I just want to know the reason for it other than leaking.
Old Oct 7, 2003 | 02:00 PM
Jime's Avatar
I don't know if it would flow enough fuel but gas leaks are a major catasrophe and all your fuel lines are 5/16"
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
