Installed new fuel TEE
Old Oct 8, 2003 | 08:47 PM
Nismo's Avatar
just got a new TEE to replace the NX 1/4" tee and this tee seems to be like 3 times the length. The length made it impossible to install using the stock line so I went out and bought a couple feet of new fuel line because Its impossible to get the stock fuel line to connect without bending the line to about 90degrees which would kink the line and block flow. I managed to make a loop so that the curvature would be as smooth as possible to allow flow. Just wondering how all you other NX guys routed their TEE? did you have to do what I did and use a longer fuel line? BTW I have a 300ZX fuel filter if that makes any difference
Old Oct 9, 2003 | 02:52 PM
XXXL Cracker's Avatar
I bought an additional length of hose. Connected it to the top of the filter and then connected it to the tee and then the other side of the tee to the stock line. I did have to also curve the line slightly and zip tied it so that it was secure. As you know, make sure you use fuel line clamps.
Big Cracker
Old Oct 9, 2003 | 05:05 PM
Jime's Avatar
Big Cracker
Old Oct 9, 2003 | 05:33 PM
Nismo's Avatar
Big Cracker
that sounds exactly what I did. Ill post a pic to show you all just to make shure it looks ok.
Old Oct 14, 2003 | 03:45 PM
97GLES's Avatar
Originally Posted by Jime
when buying a fuel pressure gauge for a 4th gen, should the gauge be 0-100 or 0-60 ?
Old Oct 14, 2003 | 03:57 PM
Jime's Avatar
If you are using it for a wet kit get the 0-60 for more accuracy. Gauge shouldn't read any higher than 43 psi. However with a dry kit you need at least a 0-100.
Turbo and S/C run higher fuel pressure than stock as well.
Old Oct 14, 2003 | 08:19 PM
97GLES's Avatar
Jime
thanks for the info.
i don't have a kit but i hope to get a wet kit in the future.
im just try to finish installing my 3 gauge pillar pod. so i ordered some gauges and 1 of them was a fuel pressue gauge that will sit outside.
i ordered the 0-60 gauge.
Old Oct 14, 2003 | 10:09 PM
Nismo's Avatar
how do you go about installing the FPG outside? Ive seen one like that right next to the wipers but Im kinda scared about theft since its so easly acessable
Old Oct 15, 2003 | 02:00 AM
97GLES's Avatar
i will install it under the hood, not on top. i ordered ATM-2179 from auto meter. it's only 1 1/2" gauge.
Old Oct 15, 2003 | 04:06 AM
Jime's Avatar
I keep mine on an 18" length of fuel injection hose then I can read it under the hood or put it next to the wipers when I am at the track.
Old Oct 15, 2003 | 07:45 AM
Hey Jime:
MY FP is reading around 41 at idle and around 48 at WOT. Any reason why this might be....bad gauge etc?
I guess I can get a mechanical gauge to test it to ensure it's accuracy.
Any ideas?
Big Cracker
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
aminus21
Sep 12, 2015 04:53 PM
Johnny9595
Sep 3, 2015 05:18 AM
