Gauges for my wet kit
Old Nov 17, 2003 | 07:18 AM
waveridr85's Avatar
i am getting the nx wet kit am wondering what gauges are best for my auto tranny car. i was thinking the following.
egt
fuel presure - will this be necessary with a wet kit?
tranny temp
a/f - i do not think i will need this
thanks to everyone that is going to help
Old Nov 20, 2003 | 08:06 PM
CBass69187's Avatar
egt
tranny temp
I would replace the A/F with a nitrous pressure and you are good to roll.
Old Nov 21, 2003 | 07:19 AM
XXXL Cracker's Avatar
egt
tranny temp
EGT, FP and Nitrous Pressure. Go electrical with the nitrous pressure. It will just make it easier to run everything. I am running a mechanical Nitrous gauge in my glove box and it adds a lot of line to your set up.
Big Cracker
Old Nov 21, 2003 | 10:50 AM
waveridr85's Avatar
i do not see the reason for running a nitrous presure, i was going to put on on the bottle though
Old Nov 21, 2003 | 07:51 PM
CBass69187's Avatar
If the bottle pressure gets to high you will run lean.
Old Nov 22, 2003 | 11:31 AM
waveridr85's Avatar
isnt that regulated somehow? and wont the egt tell me if i am running lean?
Old Dec 4, 2003 | 09:13 PM
waveridr85's Avatar
anyone? help please
Old Dec 5, 2003 | 04:22 AM
SmoothMax's Avatar
OG
A bottle mounted nitrous pressure gauge is better than none. The in cabin gauge is more for convenience although highly recommended by many. Like CBass69187 said,
this is true. Higher bottle pressure means more nitrous is being injected. More nitrous means more air in the combustion chambers. More air than fuel = lean, more or less. So what ol' boy was tryin to say is a nitrous gauge will serve you better than an a/f. And your EGT will let you know if you're running lean but how can you regulate having a higher shot of nitrous when your fuel tee is set for something else??
Someone correct me if that doesn't make any sense please...
Old Dec 5, 2003 | 07:08 AM
waveridr85's Avatar
"regulate having a higher shot of nitrous when your fuel tee is set for something else?? " i dont understand that part
i thought that when the eegt gets too hot it means i am running lean, i was no thinking of just running a tranny temp and a egt, with nitrous presure on the bottle
Old Dec 5, 2003 | 09:50 AM
Jime's Avatar
Wet kits have a nitrous and fuel jet for each HP shot. The fuel is fed at stock WOT pressure which is 43 psi (4th Gen) so the fuel volume is constant. The nitrous volume is also constant if the bottle is at the recommended pressure. (approx 1000 psi) If you don't have a bottle heater and corresponding pressure regulator your nitrous pressure could be anywhere from approx 650 psi to 1500 psi depending on the temp of the bottle.
Anything less than 1000 psi and your system will run rich and anything higher and your system will run lean. + or - 50-100 psi won't make much difference but any more and you are at risk it the pressure is high.
Old Dec 5, 2003 | 10:49 AM
waveridr85's Avatar
so will a bottle heater replace the nitrous presure gauge?
Old Dec 5, 2003 | 11:03 AM
Jime's Avatar
No, the gauge will just confirm that the bottle heater/pressure regulator is working properly.
Old Dec 5, 2003 | 11:33 AM
waveridr85's Avatar
damn, so hany many gauges are you guys running?
so far its
nitrous presure
egt
fuel presure
tranny temp
where am i going to put all of this? i didnt even plan on running more than a 75 shot
Old Dec 6, 2003 | 10:21 AM
Synki's Avatar
Run EGT, FP, Nitrous Pressure. Is there a reason why you are so hung up on the Tranny Temp? Yes that is something that is nice to have but not "fully" needed.
You will need a gauge to tell you what the pressure of the bottle is.
Get a bottle heater so it keeps your bottle pressure at the proper bottle psi w/ heat. Once the bottle has reached its certain temp, the bottle heater will shut off.
Just remember, the more heat, the higher the bottle pressure.
Old Dec 6, 2003 | 11:12 AM
CBass69187's Avatar
If he wants a tranny temp, I would get it because it is a good thing to keep an eye on. I wouldn't put it on the A-pillar however. Maybe in the glovebox or ash tray thing.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
