Questions
Old Nov 18, 2003 | 10:04 PM
danthediablo20's Avatar
Questions
Whats the diffrence in wet and dry in a maxima..Brand NOs how do uknow which one u have... Ummm..what heads should u replace wit if going for 100 shot at least...Anything else recomended for an auto tranny...OH yea um Spark plugs wit eather sit up and gaps..thanks....
Old Nov 19, 2003 | 03:49 PM
CBass69187's Avatar
N2o
Wet injects a fuel/ nitrous mixture to handle the added fuel demands when running nitrous. Dry simply raise the fuel pressure to compensate. Replace heads????? I don't have the slightest clue what you are talking about there. Auto tranny with that much nitrous you will need a VB mod and tranny cooler or a drop resistor mod and tranny cooler. You will want a new fuel pump for that much N2O and also gauges to monitor your cars performance. You may or may not need an adjustable FPR depending on the fuel pump you get. I would do a lot more research if you are serious about it.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
