prepping for nitrous?
Old Aug 7, 2003 | 10:42 PM
billy_corgan's Avatar
i am installing the nx wet kit with a friend on tuesday and was wondering if there is anything I need to do to my car before i do. Things I have already done:
-New spark plugs NGK BRK5E (these the right ones?)
-New fuel filter
-Oil change
car is a 99 with 44,000 miles. I am only starting out at a 35 shot. thanks.
Old Aug 8, 2003 | 04:35 AM
XXXL Cracker's Avatar
Re: prepping for nitrous?
-New fuel filter
-Oil change
If you have not already, purchase an EGT gauge and a Fuel Pressure gauge. You will wantto bump up the shot.
The miscellaneous things I needed were:
Additional wire
Male and female butt splices
Drill to mount the nozzle
Copper plugs, one step colder
Soldering iron for better connections.
Scout out a place to mount the solenoids
Take your time, the first time you install the kit it may seem like it is pretty involved however, it is pretty straightforward. Give yourself a good day to install it so you can take your time.
If you do get a Fuel pressur egauge you will need ad'l fuel line as well as some assorted brass fittings found at your local Home Depot or hardware store.
Also, I would go to the NX site and print out the instructions there as they are better than the instructions found in the packaging.
Also, look to get a bottle heater and a purge valve.
Any other questions please post.
Big Cracker
Old Aug 8, 2003 | 07:51 AM
I already have egt guage and oil temp guage. I will be purchasing a fuel pressure guage very shortly. would I need a mechanical guage or electrical? I bought the kit used, only a few weeks old, used once. the person who had it is helpinbg with the install and he has done it before.
Old Aug 9, 2003 | 09:29 PM
pMB's Avatar
pMB
hey
let me know how the install goes...
my nx is sitting in my room. if you take pics during install, plz share with me prophetmb@yahoo.com
thanks.
Old Aug 10, 2003 | 08:35 AM
i will take pics, send em to you on thursday
Old Aug 11, 2003 | 06:07 AM
SR20DEN's Avatar
VQ Wizard
For the much smaller shots a A/F is better than EGT. But it's best to have them both for the bigger shots.
Old Aug 11, 2003 | 11:07 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
egt and a/f is ghey. I have both. I would rather save my dough, shell out a few more and get a wideband or a greddy egt. Ugly, but accurate as *****.
Old Aug 12, 2003 | 05:19 AM
SR20DEN's Avatar
VQ Wizard
I have both and from what I have seen it's best that way. The A/F gives you the very quick readings and the EGT gives you the longer term readings.
Old Aug 12, 2003 | 07:28 AM
Eat Naaawwwzzzzz
Thats true, but do you get signal after 3400 rpm with the a/f?
Old Nov 20, 2003 | 10:33 AM
waveridr85's Avatar
do you need an air flow when running a wet shot?
Old Nov 20, 2003 | 11:05 AM
SR20DEN's Avatar
VQ Wizard
I get readings at all RPM.
96SE_dsm
Mar 24, 2001 07:39 AM
Cumalot
Mar 15, 2001 06:25 PM
Ramius83
Jan 5, 2001 03:31 PM
My 4DSC
Jan 4, 2001 07:21 PM
Cumalot
Nov 26, 2000 04:30 PM
