how much would i spend? nitrous newbie!
Old Jan 17, 2004 | 01:22 PM
michaelnyden's Avatar
I need to know how much would I spend for a NX wet kit for a maxima (obviously) and a bottle warmer, window switch, and WOT switch? spark plugs are cheap so I can don't worry about those...but with a stock ecu, 1 step colder spark plugs and stock fuel pump, what kind of shot can I run? mind you I have intake, and y pipe, cat, and b pipe and muffler right now...so I guess that is already using up some of my fuel pump's capabilities....
oh yeah, if I run a 14.4 or 14.5 quarter right now, what will I run with my street tires 235/45/ZR17 they are pretty good traction wise....after a 50 shot? 60 shot? 75 shot?
Old Jan 17, 2004 | 02:42 PM
Vyrus's Avatar
Kit - $560
Warmer - $110
Switch - $60
Pressure Gauge - $40
Plugs - $10
WOT switch come with the nitrous-oxide kit. Add shipping prices, you're looking at about $820 shipped. That's for a brand new kit. Buy all your parts used and it'll probably be about $600 (granted you'll need some new parts).
You will be able to run a 75 shot with no problems. With that shot you should be able to run 13.5ish.
-Cyrus
Old Jan 17, 2004 | 02:51 PM
plurco's Avatar
I cuncure. I normally run a 14.7 and with my NX kit and 75 shot I run a 13.6 with absolutely no traction in 1st of 2nd. My MPH is high enough for a low 13.
Old Jan 19, 2004 | 01:54 AM
what gauges would ineed? and what would they be for? i want a 75 shot wet kit that I could just put on and not have to tune except for gapping my copper colder plugs and such...other than that I don't want to have to monitor some gauges like my car will blow up or somethin!
Old Jan 19, 2004 | 03:47 AM
Nismo's Avatar
nitrous pressure
egt
fuel pressure
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
RinconI30
Nov 10, 2015 10:55 PM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ColdCananda
Sep 20, 2015 10:45 PM
