Valve-body mod
Old Jan 18, 2004 | 11:08 AM
pfactor172's Avatar
Valve-body mod
I plan on adding nitrous to my Max 01se . I know I should do a drop resister mod and trans cooler but what is a valve-body mod? nitrous
Old Jan 18, 2004 | 01:53 PM
Nismo's Avatar
you shouldnt do the drop resistor mod.
Old Jan 18, 2004 | 04:14 PM
DaThrillr's Avatar
the drop resistor mod makes all shifts(up and down shifts) hard and increases the line pressure. it is ok to do the drop mod at the track but not recommended for everyday use.
Old Feb 17, 2004 | 12:00 PM
C MAX's Avatar
a valve body goes in the tranny. it improves shifting vastly for around 400 dollars. i just had mine done at maximumtuning.. stage 3. you dont need it or the cooler unless you plan on running some serious nitrous.
but if you can afford it. why not its a beautiful mod. i ran a 70 shot without either and it didnt cause any problems..
Old Feb 17, 2004 | 12:41 PM
Jime's Avatar
The VB Mod is a compromise between everyday driving and racing.
The drop resistor mod allows you to have FULL line pressure while racing and stock for everyday, thats why I prefer it. Just make sure to put it on a WOT switch so it is never in use for part throttle.
A tranny cooler is also a must, for me anyway and get a B&M they are the best because of the built in by-pass for hot-cold operation, the Hayden doesn't have that feature. Plus they are a much sturdier construction.
Old Feb 18, 2004 | 03:01 PM
Tally Max's Avatar
Jime, do you have any write ups on installing at wot switch for the drop resistor mod or any sugesstions on how to do it? thanks
Old Feb 18, 2004 | 05:19 PM
Jime's Avatar
Check here
https://maxima.org/forums/showthread...27#post2720127
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
