Digital Maximizer
Old Jan 21, 2004 | 03:38 PM
MaxSpeedSE's Avatar
Digital Maximizer
Anyone know what this is?
http://store.yahoo.com/southwestauto...itexdigne.html
I take it that it alows u to pick what show u want to spray for each gear? Does anyone have it? How wel dose it work?
-Chris
Old Jan 21, 2004 | 09:33 PM
TAPOUT's Avatar
You will lose
Looks cool. Expensive though.
Old Jan 22, 2004 | 11:17 AM
MaxSpeedSE's Avatar
If its what I think it is, it would be defiantly worth it. cuz it would give us the advantage over superC and turbo maximas... yeah there dynos will show more HP but all that power hitting the ground is to much traction issues. Whats all that power good for if you can use it. If we can control our nitrous threw out the gears that means consistent pull hard off the line and have no traction issues, so we would have the advantage on the street, and street tires.
..I think
Old Jan 23, 2004 | 04:34 PM
MaxSpeedSE's Avatar
Anyone know ?
Old Jan 23, 2004 | 09:37 PM
SonicDust187's Avatar
Dude, I sent you a link a few days ago.
Old Jan 26, 2004 | 10:38 PM
Y2KSESteve's Avatar
I haven't had a chance to mess with one of them, but from what i know you can set it for any shot in any gear. It has all kinds of features and really is a sweet little unit.
Old Jan 27, 2004 | 12:29 PM
Luquire's Avatar
how does it know when you switch gears
Old Feb 14, 2004 | 09:17 PM
tampamax's Avatar
I think you may be better off with a Jacob's Nitrious Mastermind.
Old Feb 14, 2004 | 09:20 PM
MaxSpeedSE's Avatar
Jacob's Nitrous Mastermind.....whats that?
Old Feb 14, 2004 | 10:00 PM
tampamax's Avatar
Christ man use the same keyboard you use to make these post to google search it. It is the exact same thing as NX has tried to do, but Jacob's had been around for much longer with an impecible track record. Then if you want to still spend and run like a pro dragger look at Deadenbear(sp?-but close) for less than the NX maximizer.
Old Feb 15, 2004 | 08:13 AM
MaxSpeedSE's Avatar
I found the Jacobs board in a sumit racing i have....its runs for cheeper then the nx one, but it said its for V8s i'll search and see if they have anothere one.
oh yeah and i know i could have searched about this in the first place but the whole reason i started this thread was to see if sombody has one and how well it works.
Old Feb 15, 2004 | 08:42 AM
tampamax's Avatar
The jacobs are multifunctional 4/6/8, look on the net for greater detail on the applications they are practically unlimited. If i were you i would try ls1.com and a ford forum of some kind. Ask hem about the jacobs.
Old Feb 17, 2004 | 06:03 PM
elchino's Avatar
i guess if you really want to fine tune your system so you're repeatable every time get the maximizer. I would only get it so I could limit spray and keep traction, but then have it running full blown when I'm high in the revs.
But if I'm just going to use it to control traction, I'd rather spend the same amount of money and go dual stage: 1st stage on WOT switch at about 35 shot and maybe the 2nd stage on the button additional 50 shot. Dual stage would be a lot more fun too, but you won't get repeatable times unless you're very coordinated under pressure. (e.g. bracket racing)
Old Feb 17, 2004 | 09:01 PM
MaxSpeedSE's Avatar
i guess i could always just save up and get slicks
Serotta33
Sep 17, 2015 12:14 PM
mix master
Sep 7, 2015 08:28 PM
mix master
Sep 4, 2015 05:50 PM
Maximal
Dec 29, 2000 11:26 AM
