I'm gonna be hitting 13's soon!!!
Well after having a bad day at the track (16.1 was my best time with y-pipes, and pulley) , I was convinced by my Friend/mechanic to go with NOS.... telling me our car can handle a 100shot of it, and that most likely I'll be hitting 13's. I plan to get one of the following parts every month, with a update on my 1/4times, at the track. I dont really like using Nitrous, but its just for now, later on I will get a S/C or swap to a 5spd Here is what I have to add:
CAI Intake: comes in friday
Tranny Cooler:
VBmod:
NX Express:
JWT ECU: for Nitrous use
What do you all think?
Tranny Cooler:
VBmod:
NX Express:
I think you are about to blow your engine before you hit 14's with a 100 shot.
Yes a 100 shot can be run through our engines but you will need some tuning and also some more pars. I believe you may also need to get a better fuel pump with that shot.
I would be safe and run a 50 shot instead. Get some gauges, and keep it safe.
You will be in the 13's after some fine tuning, and practice
A 16.1? Hmm...I dunno that you'd be hitting 13's even WITH a properly tuned 100 shot...I mean granted you're an auto and auto's pretty much suck NA; and although auto's are better for nitrous I'd say you wanna brush up on some driving skills first.
Tranny Cooler:
VBmod:
NX Express:
Tranny Cooler:
VBmod:
NX Express:
I'm done.
Yea work on your driving skills and launches before you do anything else. 16.1 is horrible for a 4th gen w/ ypipe, even if it is auto. Also, make sure your car is up to par in maintainence before you start running nitrous, ESPECIALLY a 100 shot.
I really hated the auto tranny until tonight. I just installed my VB and WOW what a difference. I think you should go get a performance computer, and practice your launches. Until you are under 2.40 second 60ft times, the rest doesn't matter. The times at the track really just show how well you can get off the line. You might be able to run with anything from a rolling start, but getting out of the hole is the key. If you work on you 0-40mph you will get a good idea of where you stand to go back to the track and make a good pass.
my launch/reaction time was .431 that day everyone was sucking, srt 4's where hitting 15's, ford focus SVT hit a 16.8, my friend who has the same thing I do, has hit 15.1 that day we went to the track and he hit the same as me, it ****in blows
Near-stock they do
I wasn't referring to those auto members with built trannies and FI
Originally Posted by blubyu2k2
I'm on my stock tranny...and I have the fastest all motor street tire run on this board.
These guys are right, you should try and get into the high 14's or low 15's before you even try spray. Also like mentioned earlier get a compression test.
Muchas gracias, sorry guys yes I got a little hot headed here, I've talked to a some friend who run NOS, one of them runs a max with nos, and yeah he told me we have to get fuel pump, and slicks if I want to hit 13's or so. I wanted to know, if I go nitrous will my motor setup be slow, due to the fact am running nitrous, or will be running the same as before?? Also what can't I use on my auto***it when and if I use NOS???
doctorpullit
Dec 12, 2015 09:39 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
