50 shot nos kit.
Old Jun 8, 2004 | 07:50 AM
Maximus_95's Avatar
50 shot nos kit.
i am really really really thinking about getting a 50 shot on my car.
i currently have intake, ypipe, whole exhaust system.
with a 50 shot, how reliable is it? if it is, i will be buying a kit within a week.
help me out guys. thanx. just need to hear from what people have to say before purchasing it.
Old Jun 8, 2004 | 09:20 AM
THT's Avatar
THT
Throbbing member
I too am considering a 50 shot kit made by NX due to Jime's endorsement. After havind read all the stickies, my conclusion is that if you don't abuse nitrous and take the proper precautions, it's not as hard on your car as other forms of FI. As you're a manual, you'll want a windows switch on top of the basic kit. You'll also need a gauge and a bottle warmer.
~THT
Old Jun 8, 2004 | 12:14 PM
koldsimer's Avatar
I've had my nx system for 5 months now. I've gone through approximately 20 full bottles. It is absolutely safe if used properly. Follow all of NX's recomendations and you should be fine. The only "problem" i've had so far is when I threw my switch when the tranny was still downshifting to first. I sparayed for maybe a half second while the engine was between the gears but no damage was incurred. Otherwise, all smiles while I run with vettes! Get it! NX makes an incredible product at a reasonable price. Get it!!!
Old Jun 8, 2004 | 08:30 PM
TAPOUT's Avatar
You will lose
You will love it. It is so nice to smoke a yuppy in a Porsche.
Old Jun 9, 2004 | 08:24 AM
skandalouz's Avatar
i thought it was ok to have it activated between gears.... like if im auto.. i just floor it and leave it on between the gear shifts.. is that gonna hurt my engine/tranny?
Old Jun 9, 2004 | 11:58 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
No way man. I bet your 2-3 and for sure your 3-4 shift will slip like a ****...
Old Jun 9, 2004 | 07:32 PM
koldsimer's Avatar
It's "ok" to have nitrous spraying while at full throttle. I threw the switch a split second too quick... I was rolling along at about 8-10 mph and floored it and before the tanny had gone into first i got excited and threw my switch. No harm done it seems.
Old Jun 9, 2004 | 08:46 PM
1FSTMAX's Avatar
I ran a 55shot with no problem on my 97...
But i thought you didn't want a power adder?
Old Jun 9, 2004 | 11:00 PM
Maximus_95's Avatar
well...nos can be an exception. not that expensive and a lot of hp gain.
considering it for now, but just opening up my options.
Old Jun 12, 2004 | 07:14 AM
C MAX's Avatar
get it youll love it. with a 50 shot you can hit it anytime you want with minimum wear and tear on the car. if you use it cautiously it will probably last as long as your car. im going 5yrs strong with the stillen dry kit 60 shot and in the summer i use it every weekend basically.
Old Jun 22, 2004 | 07:10 PM
][ 35's Avatar
if you are planning on running only 50 shot...
do you need to change anything else in the car?
such as changing to colder spark plug?
Old Jun 26, 2004 | 09:53 PM
THT's Avatar
THT
Throbbing member
Yes, get copper plugs for the colder spark. You won't need to upgrade the fuel pump.
~THT
Old Jul 6, 2004 | 10:34 AM
michaelnyden's Avatar
do you need to go 1 step colder and copper if you are only planning on running a 50shot? or just switching to copper will be sufficient?
would a dry 50 shot be okay with stock fuel system and mevi?
Old Jul 6, 2004 | 01:02 PM
C MAX's Avatar
the first yr i got the 60 dry kit i ran stock platinum plus four sparkplugs without a problem and with no upgrades besides the air intake, then when i went to a 75 shot i switched over to the ngk copper one step colder only because it was recommended not because i was having problems. what happens is you get used to that fifty shot and it doesnt feel that fast anymore (thats because you attract a faster set of cars)
and you up the juice to keep up and it feels good but you have to be careful beyond a 70 shot because the fuel supply has to be adequate and the car in good enough shape to handle it but a 50 or a 60 i can vouch for being a safer method with a stock fuel pump. adding a mevi or other bolt ons will also help the nitrous burn better
Old Jul 7, 2004 | 11:17 PM
cerumo's Avatar
so copper plugs are ok to be used with 50 shot? what is the part number for ngk copper 1 step colder and how much more expensive than the bkr5e-11 copper?
Thanks.
Old Jul 8, 2004 | 02:14 AM
C MAX's Avatar
Thanks.
sure it wont hurt. im not sure of the exact number but they cost about 1.20 ea. got mine from autozone i know that the one step colder has a 6 but i can verify later when i check.
Old Jul 8, 2004 | 04:39 AM
THT's Avatar
THT
Throbbing member
One step colder: BKR6E-11
Even colder: BKR7E-11
~THT
Old Jul 9, 2004 | 12:57 PM
ChromeSE5's Avatar
Im also looking into nos but I was wondering how much it cost to refill the bottle. Any examples how much you guys pay?
Old Jul 10, 2004 | 04:19 PM
ch13f's Avatar
^ I believe people pay as little as 2$ per pound up to 5$ in areas where it's harder to find. So for a normal 10lb bottle, 20-50 bucks.
Maxboy23
55
May 1, 2025 06:09 PM
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
brichi
Sep 15, 2015 07:20 AM
Stagnet04
Sep 13, 2015 09:32 PM
